Go to Post I'm not gonna reinvent the wheel cause I can already buy it :) - Stephen Kowski [more]
Unread 11-02-2002, 13:20
Brian Savitt's Avatar
Brian Savitt Brian Savitt is offline
#0056 (ROBBE Xtreme)
Brian Savitt will become famous soon enoughBrian Savitt will become famous soon enough
Send a message via AIM to Brian Savitt
Look for heavier pieces of material on your robot and think what you could replace it with that would make it lighter, and there is always the option of drilling a million holes
Brian Team 56
Unread 11-02-2002, 13:22
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Talking Re: Luan Plywood is a blessing.....
Originally posted by Chris Hibner
I forgot another thing: Lexan (and other plastics).
Wherever possible, substitute Lexan instead of aluminum. This is advisable only when the part you're substituting doesn't carry much load (if it carries a lot of load, you'll need to do some calculations to see if it will survive and not bend too much). For instance, all of our control system parts last year were mounted on an aluminum plate. We replaced the aluminum with Lexan and saved about 2 lb. The heat conduction properties of aluminum was nice, but the matches only last 2 minutes so it's not that necessary. You may need to reinforce the Lexan with a couple of thin aluminum strips to keep it from sagging too much, but overall, you can save a lot of weight.
Also, a lot of bearings can actually be replaced with delrin bushings. I would keep the bearings in your drive wheels, or other areas that cary an enormous amout of load, but delrin bushings are adequate for most spinning shafts that don't carry a lot of loading.
Just remember that you don't need to design your robot for infinite life. As long as it lasts a few months, it will be fine.
And then if you find Lexan too dense for your weight budget, you might want to look into Luan Plywood.
Luan Plywood is 1/2 the density of Lexan.....sure, it isn't as strong, but there is alot of lexan use that is simply there to things like ball containment....not requiring so much for strength.
-Quentin
Live free or die....
Unread 11-02-2002, 13:32
CaptainPlaid's Avatar
CaptainPlaid CaptainPlaid is offline
#0314 (Megatron Oracles "Big MO")
CaptainPlaid is an unknown quantity at this point
Expanded aluminum is also a good option for things like ball containment and even for supporting top and side loads if you give it a bit of support. Last year we used it as the deck on our robot and it worked wonderfully. It would support humans and robots. Essentially it is plate aluminum with more holes drilled in it than you could possibly do on your own.
I have not failed. I have just found 10,000 ways that won't work.
Thomas Edison
Unread 11-02-2002, 16:25
Neill Means Neill Means is offline
#0933 (Sallgood)
Neill Means is an unknown quantity at this point
Weight-don't push the bleeding limit.
Practical Weight considerations for Rookie Teams!
A Note from a Veteran:
If your 'bot weighs 130.0 lbs, my suggestion is to get it down to
129.5 lbs. The difference is small, but the difference between your shipping scale and the USFIRST shipping scale could be the difference between 1/2 pound (about 0.5%)
According to the rule books, the USFIRST scale at checkin is the "absolute" authority, so if you are 0.1 lbs over, they will not let you compete until you are 130.0 lbs by THEIR scale. There is NO debating with the officials about the accurracy of their scale at the competition. NONE!
If you want to live on the bleeding edge of a 0.5% margin of error, then show up with a 'bot at 130.0 and bring power tools for cutting.
Rookie teams should probably bring their 'bot in at 129.5 lbs. Use a recently certified shipping scale that has a weighing platform at least as big as your robot is. The shipping scale will be a monster! Bathroom scales will give you false readings.
Neill Means
Team 933
P.S. Do you know that Earth's gravity changes according to where you are in the world? So, different masses (your robot) can have different weights in different parts of the world (small differences).
Unread 11-02-2002, 17:47
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
I agree with Neill. Get the weight below 130 lbs. We use the wrestling scale at the school. Very accurate. Still our bot gained a 1/2 pound from regional to the championship.
Wayne Doenges
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 11-02-2002, 18:03
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Other Variations
I don't know about this year, but the scales used last year also had a slight variation depending on where on the platform you placed the robot. As I recall it was definitely to your advantage to get the robot CG centered on the scale. Note: depending on your robot design that may not be the center of your robot.
For us it was the difference between making weight and getting out the drills
Christopher H Husmann, PE
"Who is John Galt?"
Unread 11-02-2002, 18:34
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: Other Variations
As a wrestler, I am familar with this. The scale at are school, you could shave 1.5 lbs by putting all the weight towards the left edge of the scale, and similar type things on the other scales at the diffrent schools. Don't know why, but thats just they way it is.
Viva Olancho!
Unread 11-02-2002, 22:32
Matt Reiland's Avatar
'The' drive behind the drive
I wish first would let the robot weight be 131 pounds
Ohh well we came in at 131 fully loaded and we were actually able to shave off 4lbs off the electrical system if you can believe it. The terminal strip and a huge amount of 10 ga. wire is now on the floor and we have more weight now for armor. By far the biggest weight cam from gears, we were able to reduce most of the larger 20 pitch gears by 70 % by turning down hubs and drilling holes, and in steel terms thats alot of weight sometimes over a 1lb at a time. Also look into the fastners on the robot, we found BOSCH gussets in places they were not needed and extra t-nuts where they weren't needed. Heck we welded a bunch of parts to make them lighter also.
Unread 11-02-2002, 22:49
Wetzel's Avatar
DC Robotics
I wish we could weld....
Viva Olancho!
Unread 12-02-2002, 01:50
Patrick Wang Patrick Wang is offline
#0115 (MVRT Alumni)
Patrick Wang has a spectacular aura aboutPatrick Wang has a spectacular aura about
Send a message via AIM to Patrick Wang
Fully Welded Assembly=not fun for welder
This is just the slightest bit ironic since I just finished 4 and a half days of welding for our ball mechanism.
Welding 0.049 wall aircraft tubing is not fun. Makes you also have to bend your body in the wierdest of ways. All while TIG welding.
I'll say it was a challenge, but certainly not the most fun thing I've had to do heh.
Patrick Wang
WRRF
Unread 12-02-2002, 17:17
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
Uggg!! 20-25 pounds over. Must dump components. Crap...stupid planning.
~Adam
Unread 12-02-2002, 19:13
Radiant Phoenix's Avatar
Radiant Phoenix Radiant Phoenix is offline
#0481 (DART)
Radiant Phoenix is an unknown quantity at this point
Extremely Over Weight
Dude, we were almost 70 pounds over at one point, and we were incredibly worried that we'd never get down to 130. We have to drill so many hole in our steel, and we lost half our treds to casters. Almost there though.
Remodeling was a last resort, but last resorts are often necessary. ::sighs::
Good luck on the Robot diets Minna-chan!!!
Athena
"Not all those who wander are lost." ~J.R.R. Tolkien~
" 'I wonder if they do exist...'
'Who?'
'The Elves.'
'Of course they exist- I'm the First one.' "
~The Vendori Chronicles; By Athena~
De Anza Robotics Team
Unread 12-02-2002, 22:11
SharkBite
Posts: n/a
if youve got so much steel you might want to try aluminium or titanium if you can afford it
Unread 13-02-2002, 08:55
dets002's Avatar
dets002 dets002 is offline
#0811 (Cardinals)
dets002 is an unknown quantity at this point
Send a message via AIM to dets002
Put the controls system close together and especially have the thermal breakers close to the battery, because the six gauge wire is very heavy. Try to position electronics so that you use the least wire as possible. Thats how our controls team dealt with weight.
Unread 13-02-2002, 09:17
Andrew Dahl's Avatar
Andrew Dahl Andrew Dahl is offline
#0497 (Orange Crush)
Andrew Dahl is an unknown quantity at this point
carefuly placed holes in teh battery
(that joke gets better every year)
dahl
2002 VCU Regional winner of the GM Industrial Design award
whooot!
Rookie advice for the Championship Event Carolyn Duncan Championship Event 2 07-04-2003 17:57
advice on starting a team.. archiver 2001 1 24-06-2002 03:20
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Regionals start in one week - final advice or tips Mark Pierce General Forum 2 02-03-2002 18:49
Robot dimensions & weight restrictions revealed? Mike Soukup Rules/Strategy 4 24-10-2001 20:51
