Go to Post Let's not complain when we are getting magnificent items in the kit that teams just a few years ago could only wish for. - sanddrag [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 03-12-2003, 14:31
Dr.Bot
Posts: n/a
Can you use PWMs (Red or Blue) with the edubot controller?
I didn't use the Edubot last year, so can I just use a 3 wire connector to connect from the Edubot rwb to a Blue or Red Innovation First or other PWM contoller. (Obviously the power would come from a separate battery.)
Thanks.
Unread 04-12-2003, 18:47
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Can you use PWMs (Red or Blue) with the edubot controller?
Yes, the PWM outputs of the Edubot RC generates a standard hobbyist RC pulse. This can work with the Edubot Motors, Standard RC Servos, or Standard RC speed controllers (including the RC speed controller sold by Innovation First, the Victor 883 or 884 Red or Blue).
Joe J.
Thanks.
Unread 04-12-2003, 23:21
Dr.Bot
Posts: n/a
Thanks.
OK What is the fourth (orange) wire for?
PS. I tried getting a red victor to work without luck.
Unread 04-12-2003, 23:51
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
The fourth wire (orange, opposite the black wire) is just another +V pin. It performs the exact same function as the second wire from the black side (red).
As a rule of thumb, never just connect two things together, unless you seriously know what you're doing, and how you're doing it. In this case, if you connect these things in the wrong orientation and position, there's a good chance you could damage the components permanently.
I highly recommend that you read the EduBot documentation from Innovation First's website. Here're some links:
http://innovationfirst.com/FIRSTRobo...umentation.htm
http://innovationfirst.com/FIRSTRobo...2003-11-14.pdf
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Tether for new EduBot Controller gburlison Programming 9 18-12-2003 17:53
EDUBot controller app seanwitte Robotics Education and Curriculum 0 02-11-2003 19:53
Red Vs Blue!!! DarkRedDragon Chit-Chat 1 31-07-2003 21:34
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
Red, Blue and Green Signs....HELP!!! ssjspawn Off-Season Events 3 17-11-2001 05:10
