Go to Post We fail to present a coherent picture of what we are if we aren't vigilant about our self-image. - Alan Anderson [more]
Unread 12-02-2002, 12:28
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #0930
Team Role: Parent
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
Motor wire sizes
Does anyone know the official rule for wire sizes to the motors? The black Atwood motors have 16G wire on them. Do we really have to use 10G wire to extend to the speed controllers?
We want to solder wires directly to the drill motor and fisher price motor leads. 10G wire is very stiff and in my opinion overkill for the application. We want to use 14 or 16 G.
Does anyone know what FIRST will be inspecting for?
Unread 12-02-2002, 12:34
Tim Skloss's Avatar
Dr. Skloss
FRC #0930
Team Role: Parent
I answered my own question in Update #4. The inspection list specifically says 10G wire to the motors in my question.
Now, to find really soft, flexible 10G wire. I'm going to call my local car stereo shop to see if they have high-strand-count 10G wire. Even the 6 G wire they sell (not cheap, by the way) is quite limp and flexible. Far easier on motor leads than the wire supplied in the kit.
Unread 12-02-2002, 12:47
CaptainPlaid's Avatar
CaptainPlaid CaptainPlaid is offline
#0314 (Megatron Oracles "Big MO")
CaptainPlaid is an unknown quantity at this point
Be sure to watch the color of the wire if you get it at a car stero shop. We all know that blue wire looks good in a car but FIRST likes Black with White or Red.
I have not failed. I have just found 10,000 ways that won't work.
Thomas Edison
Unread 12-02-2002, 20:30
thedillybar thedillybar is offline
#0894 (Chargers)
thedillybar is an unknown quantity at this point
Send a message via AIM to thedillybar
Even though the chalupa motors come with red and yellow wire. Not to mention neither is always positive or always ground since they can be run in reverse.
Unread 12-02-2002, 20:53
Joseph F Joseph F is offline
#0506 (Steel Friars)
Joseph F is an unknown quantity at this point
Send a message via AIM to Joseph F
didn't they say that you only need black or red on things that are always positive or always negative. otherwise any color can be used? I'd double check this but my copy of the rule book is sitting in my car.
One Team, One Bot, One Fleet of Ambulances!
Unread 13-02-2002, 07:44
Tim,
We solder our wires to the motors. Be sure to clean the terminals first, some are plated and do not take solder so we have to scrape to base metal to get a good bond. It might help to split the strands of the #10 into two bundles, tin them, then crimp the two around a terminal and hold in place while soldering. Then form the wires (bend at right angle)over the end of the motor housing so as to keep some space between the sharp edge of the housing and the wire and then tywrap in place to keep any side load off the motor terminal. If you expect the motors to run hot(FP and drill) then the addition of a teflon sheet between the wires and the motor housing where you tywrap will prevent insulation damage during competition. Of course, heatshrink is implied to cover the joint.
A little hint while we are tallking about motors. We color code our systems so that a motor, it's associated speed controller, breaker and PWM cable and PWM output, all have the same color tape applied for easy identification when troubleshooting. If we want to kill the "brown" motor we just remove the "brown" circuit breaker.
Good Luck All
32DP gears (odd sizes) Andrew Technical Discussion 11 11-04-2004 01:24
Hex key sizes archiver 2001 3 24-06-2002 01:21
30" ball sits up there real pretty archiver 2001 18 23-06-2002 22:49
Pit Sizes at Nationals archiver 1999 4 23-06-2002 22:19
Regional Sizes D.J. Fluck General Forum 8 25-10-2001 17:26
