Go to Post So, you're saying there's a correlation between hard work and success? Who woulda thunk it?! - Tom Bottiglieri [more]
View Poll Results: What do you use for chassis material?
wood 11 5.07%
steel angle 8 3.69%
aluminum angle 36 16.59%
steel tubing (round or rectangular) 2 0.92%
aluminum tubing (round or rectangular) 58 26.73%
Bosch extrusion or similar (aluminum or steel) 89 41.01%
Other 13 5.99%
Voters: 217. You may not vote on this poll
Unread 05-12-2003, 12:59
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Too heavy
Originally Posted by M. Krass
Though the 8020 extrusion itself may be lighter per foot than box aluminum, don't forget to factor in the weight of the additional fasteners and joining plates required to make it all stay together. If a team has access to aluminum welding equipment, it's probably lighter to weld a frame together from box aluminum than to make it from extrusion -- depending on its design, somewhat.
Let's see.
If you're using say 25 feet of 1" 80-20 for your frame, you'll save about .4 lbs over box.
40 1/4-20 bolts at 5/8" long, 8 of those corner fasteners (about .025 lbs each) and prolly about a foot and a half of 1" x .125" angle (at .2742 lbs / ft) gives you fasterner weight total of about .752 lbs...
<math skipped, have faith in my algebra>
So using 1" 80/20 for your frame is about 3.1% heavier than box aluminum, fasteners included. (13.17 lbs vs. 12.78 lbs)
Absolutely worth it IMHO.
Image Discuss: Team 190 - Completed chassis CD47-Bot Robot Showcase 17 20-02-2003 17:37
Image Discuss: Chassis Teaser CD47-Bot Robot Showcase 4 10-02-2003 23:00
the provided chassis material Andrew Dahl Kit & Additional Hardware 5 09-01-2003 15:26
Sheet Aluminum Chassis: fs_2002 Technical Discussion 4 17-10-2002 10:10
Chassis ark_1230 Technical Discussion 2 04-09-2002 22:51
