Go to Post ..this is the first robot we've built that succeeded at everything we wanted it to. It was simple. It was low maintenance. It scored effectively. It had an autonomous that worked. Its look caught attention. And it was finished on schedule. - Donut [more]
Unread 05-12-2003, 21:33
GregTheGreat's Avatar
GregTheGreat GregTheGreat is offline
GregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura about
2003 Bar Height
Does ne1 remember what the height to the bottom of the bar was from the 2003 season. I am refering to the bar that seperated the two robot starting areas. The old FIRST documents says 14 inches to the top... does ne1 know the bottom measurement?
Thanks,
-Greg The Great
Unread 05-12-2003, 21:35
apk apk is offline
Hi Everyone, I'm Back.
AKA: Andrew K.
#0104 (Team Universal)
apk will become famous soon enough
Send a message via ICQ to apk Send a message via AIM to apk Send a message via MSN to apk Send a message via Yahoo to apk
Re: 2003 Bar Height
I think that 14 inches was the clearance. +/- 1 due to the floor surface.
~Andrew
http://www.team104.com/
Unread 05-12-2003, 22:45
Re: 2003 Bar Height
So you are saying if a robot was 13 inches it would easily be able to fit under the bar?
Thanks,
-Greg The Great
Unread 05-12-2003, 22:52
apk apk is offline
AKA: Andrew K.
Re: 2003 Bar Height
According to a member on my team, our 2003 robot is 14 inches high and we had no trouble fitting under, so, yes 13 inches will fit fine.
~Andrew
root root is offline
root is an unknown quantity at this point
Send a message via AIM to root
Re: 2003 Bar Height
That is what i remember from last year. you can veiw the archived documents from last year on the FIRST site.
Unread 05-12-2003, 22:56
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: 2003 Bar Height
its 17 inches
I remember it like it was yesterday
Unread 05-12-2003, 22:58
Re: 2003 Bar Height
are you sure that it was 17 inches?
Unread 05-12-2003, 23:04
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
Re: 2003 Bar Height
no it was 14
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 05-12-2003, 23:06
Re: 2003 Bar Height
That is what i have found on the FIRST website
Unread 05-12-2003, 23:15
apk apk is offline
AKA: Andrew K.
Post Re: 2003 Bar Height
Found proof:
http://www2.usfirst.org/2003comp/200..._blueprint.pdf
Take a look at the blueprints, bottom right corner. It shows the bar and the measurements. (Note: the 16" shown is to the top of the bar.)
~Andrew
Unread 06-12-2003, 00:00
Re: 2003 Bar Height
Thanks For The Help All!
-Greg The Great
Unread 06-12-2003, 16:53
AKA: Ty
Re: 2003 Bar Height
woops! ya, it was 16, not 17
Where did i get 17 from tho?
Unread 06-12-2003, 21:03
apk apk is offline
AKA: Andrew K.
yes, 16" - 1 1/4" (bar width) = 14 3/4" or 14" to be safe.
~Andrew
The Science Channel to broadcast FIRST documentary Andy Baker General Forum 49 01-03-2004 14:03
The Autodesk Design Awards 2003 – Call for Entries Brandon Martus 3D Animation and Competition 1 26-12-2003 18:40
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
Grab bar on bottom of goals archiver 2001 0 24-06-2002 00:49
stretcher & goal ...? archiver 2001 3 23-06-2002 23:05
