Go to Post Good judgement is the result of Experience. Experience is the result of Poor Judgement. - ChrisH [more]
Unread 07-12-2003, 17:49
crazy_ratchet crazy_ratchet is offline
#0321 (Robo Lancers)
crazy_ratchet is on a distinguished road
Send a message via AIM to crazy_ratchet
press fitting
please excuse an ignorant first time post, but, coult someone help me out. how are things suppoed to be properly pressfited, and what is that device called? the old put a wrentch to it and hit it somewhat worke dfor us last year, but tended to damagde things a bit. is it the same thing to press fit the thing together as to pull them apart? if there is another thread that has that could someone please point it out, for i did not fing any.
Unread 07-12-2003, 18:15
Umm Errr...
Re: press fitting
the tool you are trying to think of is a bench press. I don't know much more about pressfitting than that.
1139 Alumni
Unread 07-12-2003, 18:26
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Re: press fitting
The TechnoKats use something called an Arbor Press. It seemed to work really well as long as you had everything lined up right.
Purdue Alumni
Cummins, Inc.
Unread 07-12-2003, 18:40
DaBruteForceGuy's Avatar
DaBruteForceGuy DaBruteForceGuy is offline
aKa - Steve Bennett
FRC #0125 (NUtrons)
DaBruteForceGuy is an unknown quantity at this point
Send a message via AIM to DaBruteForceGuy
Re: press fitting
... and remember,if you have neither of th above, Brute force is always a great way to go :-)..... just remember when *tapping* into position to do it with a soft p[eice of wood (pine) between the hammre and the bearing... also try to evenly press it in all around the circumference
Team
810 > 2001-2005 - Student Founder
125 > Present - College Student
---The pessimist complains about the wind, the optimist hopes that the wind will change... the realist adjusts the sail.
***<Therapist> Tell me, is the glass half full or half empty?
***<Engineer> Neither, the glass is too big.---
....Uh, GO NUTRONS!
Unread 07-12-2003, 19:01
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
Re: press fitting
An arbor press is good, a hydraulic press is better. A bench vise will also work in a pinch, if you can extend the handle enough (put a steel tube around the handle or something). A hammer and punch will work for dowels, and instead of using a piece of pine between a bearing and a regular hammer you can use a deadblow soft-faced hammer.
A standard tolerance I use as far as making the holes for bronze bushings/bearings and dowels is diameter +0.000"/-.0005", by reamer. If no reamer is available... uh... an equal size or slightly undersize drill bit *may* work (1/64" under).
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 08-12-2003, 14:35
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
Re: press fitting
If you can, tap a hole in to the middle of the saft and use a piece of all thread and a washer to draw the part into place. An arbor press is the best. I personally don't like hydrulic presses because it takes the "feel" out of it. Remember if you are pressing a bearing into place only press/hit on the bearing race that is in contact to the surface it is being moved on. Example, if you are pressing a bearing onto a shaft press/hit on the inner race, if you are pressing a bearing into a pocket press/hit on the outter race. This keeps you from damaging the bearing. If you can't afford a press a great tool is a punch. It helps direct your hammer blows to where you want them.
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 08-12-2003, 17:15
Woodie Flowers Award
Ken Patton Ken Patton is offline
purple
FRC #0051 (Wings of Fire)
Ken Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond repute
can also stake in a pinch
If you are talking about retaining a bearing in a plate and you don't expect significant axial load (which you shouldn't with ball bearings), another approach if your hole is not small enough is to "stake" the bearing in place.
You stake it by using a pointy punch (gee Ken thats awful technical) and indenting the plate just outside the diameter of the hole. This pushes enough material into the machined bore to help retain the bearing. You might want to put indents at 3-6 locations around the hole. I would NOT use this method if the bearing is seeing any axial loads.
The advantage of this is that you don't need a press. The disadvantage is that you are hitting your nicely-machined and partially-assembled parts with a hammer.
Regarding press-fits: it is possible to do some relatively simple calculations to determine the theoretical holding power of a press-fit. Although, asking an experienced machinist is usually quicker.... )
Ken
Unread 08-12-2003, 18:03
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: press fitting
Also be aware that to successfully press fit a bearing will depend on the size of the hole into which you are pressing the bearing (or axle or shaft or whatever), the ratio between the hole diameter and the bearing/shaft diameter, and the materials being pressed together. All these elements are inter-related, and have to be considered.
Press fitting works by forcing a too-large peg into a too-small hole. To fit, either the peg, or the hole, or both, have to distort. That distortion generates huge friction forces between the parts, and they become "frozen" together (up to a point). The combined part can then withstand significant torques without moving relative to each other.
But how big should the "peg" be, or how small should the "hole" be, to make this happen? There is not a single answer to this. If one part is plastic and the other steel, then you would get a significantly different amount of distortion (higher) and resulting torque resistance (lower) than if both parts were steel. You have to calculate what size you want the "peg" to be after pressing, and how much the materials are going to distort, and from there solve backwards to figure our how large the original peg and hole should be to get what you want.
So it is not just a case of "drill the hole one size under and jam it in there." But, fortunately, a lot of the work has already been done for you. For most of the type of problems we are going to have with FIRST robots, you just need to identify the materials you are using and the size of the "peg," and then look up the reference tables in Machinery's Handbook or a similar publication. For simple cylindrical bearings as are mentioned above, this page gives a very good set of general answers.
There is a nice, fairly straightforward description of how this all works and the steps for properly press fitting bearings (including cartoons!) in the Installation Guide for Drill Jig Bearings. If you want to see a more detailed explanation of what is going on, check out this description in The Engineers Toolbox (which is a great resource you should know about anyway).
-dave
26 days to go!!!
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
Bosch Pinion JamesJones Motors 18 23-02-2003 00:20
SCRRF Press Releases Redhead Jokes Southern California Regional Robotics Forum 0 25-11-2002 15:07
Can a student Coach press the Stop Button archiver 2001 3 24-06-2002 02:39
need help writing a press release archiver 2001 1 23-06-2002 22:49
