Go to Post Haters gonna hate, Cheesers gonna cake. - Ryan Dognaux [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 06-12-2003, 10:57
iBob's Avatar
iBob iBob is offline
Extreme Mac Geek
AKA: Christopher Jones
#0240 (Mach Vee)
Team Role: Webmaster
iBob is an unknown quantity at this point
Send a message via AIM to iBob Send a message via Yahoo to iBob
Question The New Team 240 Site
I'd like some quick feedback on the design of the new Team 240 site. Keep in mind not all the pages are up, and not all of them have the new content, for example the member bios is not right. I'm mainly looking for feedback on the design aspect. The New Website
Visit Team 240's Homepage
Unread 06-12-2003, 14:56
robot180's Avatar
robot180 robot180 is offline
Webmaster, spamrobotics.com
AKA: Jon
FRC #0180 (S.P.A.M.)
robot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to all
Send a message via AIM to robot180
Re: The New Team 240 Site
I think you did a great job with this site. I have a few suggestions.
It looks like the table of contents (down the left side) is right aligned. You should center align or left or whatever you want just as long as it has a little space on each side of the words. It looks a little like they are sort of cut off by the black to the right of them.
You might try making a sort of hyperlink hovering effect. For example, make the links change color when the mouse moves over them.
I noticed that you don't use a stylesheet. I like to use them, but that is entirely up to you. It doesn't matter what you use. It's how it comes out in the end, but I wanted to say that I like how everything is layed out with tables. That is my style as well. I don't know why no one else likes doing that. I am also not sure if it was typed out or made in a WYSIWYG editor. The only thing that matters is how it works in the end.
It got a little confusing, navigation wise, how you set up your hyperlinks in the column on the left. When I went to the page, I assumed I could use those to navigate or use the ones across the top. I later realized that the ones on the left change depending on the page that is linked at the top. In other words, you might try making two sets of links, side by side, on the left, where the left set never changes from page to page, but the right set does for each section of the website.
I don't know if that made any sense. Good luck.
-Jon
Computer Science Major
Georgia Tech
Former Team Leader
FRC Team 180
Unread 06-12-2003, 15:29
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
I will reserve any real critiquing until there is more to see, although I am bit confused as to why you decided to redesign an already nice site; you have one of the nicer team sites I've seen in FIRST.
Anyway, I'll try to keep this to an aesthetic degree rather than actual coding methods for now as I understand this is a preliminary version. At this point, I must say that the 'old' site is quite a bit nicer IMO. May I suggest changing the font to a sans-serif such as Arial (be sure to include "sans-serif" as a backup)? The layout and the font don't seem to agree. I did a quick test and found that a sans-serif font that was a bit smaller than the default looked pretty decent with the general layout.
For this site, I would urge you to use a minimal stylesheet for simple but common things. The addition of the aformentioned two font rules to the body element helped a lot universally. You can use this also to define the colours and rollover effects of your links, especially in the navbar.
In all, a good start; PM me if you'd like some more thoughts or help.
Unread 06-12-2003, 16:37
iBob's Avatar
Extreme Mac Geek
#0240 (Mach Vee)
Thank you for the good feedback. I'm going to be changing the alignment of the left navigation to centered i believe... and also addign a stylesheet that will include rollovers. Thanks for the feedback and keep it coming.
P.S. I'm glad you like the old site. I would keep it but there are many reasons to change. The most important being 56k users. Downloading all those images for the design part is far to slow for my taste. I have other reasons too but I also like changing things up. Experience is good
Unread 06-12-2003, 17:35
iBob's Avatar
Extreme Mac Geek
#0240 (Mach Vee)
Ok, I added a stylesheet. What do you think? I'm not very experienced t stylesheets (in facti basically just now figured it out). Please give suggestions, and if you have a good idea for the stylesheet please give me a little help with what you mean becuase i don't have much idea. Thanks!
http://www.nuge.com/~christopher/robotics/about.html
Unread 06-12-2003, 19:43
Ten times better already! You don't need an extensive stylesheet, and in fact what you have is pretty good. I would leave it at that!
Unread 06-12-2003, 20:01
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
Thumbs up Re: The New Team 240 Site
its lookin pretty cool
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 07-12-2003, 12:55
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
And also, dont forget to create either an index.html page with an intro or modify htaccess to redirect to news.html (or rename it to index). Displaying a directory listing to users who enter the site by typing just http://www.nuge.com/~christopher/robotics/ is not a good idea
Unread 07-12-2003, 18:29
iBob's Avatar
Extreme Mac Geek
#0240 (Mach Vee)
The nuge.com is my personal webspace I'm using as a test site right now. There will be an intro page I jsut haven't had time to throw it together yet. I'm glad you like the stylesheet... keep the comments coming.
Unread 08-12-2003, 16:49
robot180's Avatar
AKA: Jon
I have a suggestion that you might think about, but it doesn't mean you should definitely do it. Take a look at your site. Pretend you are some old lady that does not know what a robot is and somehow ends up at your website. They have to know exactly what your site is for without much reading. Making some type of visualization on the home page may help. You could try putting a picture of your robot. Now you have to remember that this old lady probably isn't paying a lot of money and is getting an extremely slow, cheep internet connection through the slowest modem on the market. You should make the picture a sort of small thumbrail type pic that they can click on if they want the full sized image. This will help them to quickly learn what all this talk about robots has to do with the team mentioned in the website.
-Jon
Georgia Tech
Former Team Leader
FRC Team 180
Unread 08-12-2003, 21:25
iBob's Avatar
Extreme Mac Geek
#0240 (Mach Vee)
hmm interesting take on design. I'll keep that in mind as I make the next round of revisions. Thanks.
Unread 08-12-2003, 23:04
I originally figured you were aware of this and just ignoring it for now, but now I see why you wouldn't be; in resolutions above 1024 x 768 (which I run in), the top blue header splits apart into the seperate images it is made up of. I think you're going to want to fix that.
Unread 09-12-2003, 18:21
robot180's Avatar
AKA: Jon
If we are talking about the same thing, it does split on mine.
-Jon
Georgia Tech
Former Team Leader
FRC Team 180
Unread 10-12-2003, 05:24
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
I have the same problem with blue title bar in both IE and Opera.
Also, your page is very 'edgy' (like the edges are nice and sharp). I think if justifying the text alignment in your paragraphs would make it look nicer. It would make it fit with the 'sharp' design. You can do this with either the <p align="justify"> or in your stylesheet p {text-align:justify}. Just my two cents.. Good job, though
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 10-12-2003, 19:18
iBob's Avatar
Extreme Mac Geek
#0240 (Mach Vee)
Ok, I'm sorry I haven't had the chance to test in above 1024x768 resolution, i don't have a monitor that goes higher. I'll try to test it on someone elses computer and resolve that issue. I'll also look into the justifying and stuff. Thanks again... and keep the feedback coming. I plan to update the test site again soon.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
Team 60 new site Fat Alex Website Design/Showcase 12 26-10-2003 23:37
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
What do you use to make your team site!? activemx Website Design/Showcase 68 15-01-2003 18:32
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
