Go to Post Conspire to Inspire despite what may transpire ! - Bill_B [more]
Unread 26-11-2003, 00:02
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Worn Shifting Dogs
I have been doing some research on transmissions, and it seems that many teams are using "two speed shift-on-the-fly" transmissions that use a shifting dog to engage one gear ratio or another by locking together with a counterpart. I was originally thinking of a tranny with a similar mechanism, but I was worried that the shifting "on-the-fly" would result in a very violent transition between high and low gear, in addition to excessive wear on the shifting dog, from meshing with it's gear-mounted counterparts. Is there a trick to these transmissions, or do you just have to move the dog really really fast and hope it doesn't grind against the dog gears? If my concernes are justified, then what kind of life expectancy do you get before you have to replace the dogs?
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 26-11-2003, 01:15
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
If you are going to design this yourselves (which is pretty involved), you never know, but apparently the Technokats never had trouble with their dog mechanism. If you're skeptical, don't throw in a shifter at all; we did it last year and performed well. Of course, that's not to say you can't or shouldn't. Shifting is sexy. But, if you decide to make your own or fashion it after another team's design, just to be sure to machine its dog components out of steel and make sure the track for the dog rides smoothly (and keep tolerances to a couple thousandths of an inch). If you do that, the dog shouldn't deform at all, no matter how much normal wear it gets. It might be loud (all the better ), but as long as it doesn't deform, it should lock beautifully every time as a little throttle is applied to get everything turning and lined up. I think.
Unread 26-11-2003, 01:42
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Jon's description is very good. I don't have anything to add, in that regard, but just as a precedent, teams have been making drivetrains that shift gears for a good while, at this point. A lot of them have done this by jamming one set of gears directly into another, and for the most part this has worked well, to my knowledge
If you're worried about wear in a dog mechanism (assuming that you're using (a) pneumatic actuator(s) to shift), you can adjust the force which the actuator exerts, and thereby reduce the force which would cause the wear, in the first place. However, if you decide to construct this mechanism, I'm almost certain that the pressure of the pneumatics system will be a fairly minor consideration. As long as you don't use a 2" bore actuator, I'm pretty sure the shear strength of gear steel will be more than adequate.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 26-11-2003, 08:12
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Dogs wear/break/etc...
From talking to several of the folks who roll their own shift on the fly transmissions, I have gathered that there are significant wear/breakage issues with this type of transmission.
This isn't to say that they are not managable or that the benefits are not worth it, but it is not as simple as some folks may think.
For what it's worth.
Joe J.
Unread 07-12-2003, 22:48
Umm Errr...
Re: Dogs wear/break/etc...
bump
1139 Alumni
Unread 07-12-2003, 23:42
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: Worn Shifting Dogs
the Technocat tranny's dog is solid steel, as well as the reciving dogd milled into the gears. and it only had to work 2 minutes at a time say 30 times Thats a bit much but i imagine it would hold well never the less
Unread 08-12-2003, 08:43
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
We've been using this type of shifting (the "dog"-style) over the past two years on FIRST robots and have not had one iota of problems in that area.
This style of shifting was not invented by us... these dog engagement gears are frequently used in motorcycle racing transmissions. The benefit with this sort of gear switching is that there is no clutch needed.
Andy B.
Unread 21-12-2003, 15:58
jburstein jburstein is offline
jburstein is an unknown quantity at this point
You seem to have gotten a lot replies but few answers. I'm not an expert, but I think the answer is yes, there is the potential for quite a bit of shock load on the dog as it engages. There are two answers as to why the dog does not "wear," I would bet that most teams who use this type of tranny have software that does some type of "speed matching," so that the dog and the gear are moving at approximately the same speed when they engage, reducing the shock. The other answer is that the dog is made out of some pretty beefy steel, so it can handle the load for many cycles. Eventually it will fatigue, but the Technokats at least seem to be saying that after two years of competition/off-season competition exhibitions etc. they still haven't broken anything.
In short the answer is avoid breakage with speed matching and beefy design.
Unread 21-12-2003, 17:11
IrisLab's Avatar
IrisLab IrisLab is offline
AKA: Dave Page
#1466 (Webb School)
IrisLab will become famous soon enough
Question Re: Worn Shifting Dogs
Can some describe a "dog" system? Or point to a good white paper? Unforntunately, "dog" is a very common word and google is more than happy to rain my search with cats and dogs!
Any engineering drawings available? Sketches? More importantly, equations!
David Page
Unread 21-12-2003, 17:34
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
the technokat white paper is http://www.technokats.org/documents/shiftonfly.pdf
for the 2003 two motor design
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 21-12-2003, 19:31
Matt Reiland's Avatar
'The' drive behind the drive
Exclamation Re: Worn Shifting Dogs
Last year we were using the Generation 1 Technocats shifter that had the separate dogs mates attached to the gears. In practice we had assembled the transmission too narrow and while at full speed it shifter and ended up in high and low immediately locking up the transmission and shearing off the three screws that held the dog mate onto the gear. We took it apart and welded the gear to the dog mate and it worked for a while longer until it was assembled yet again narrow. This time, under a full power shift it again locked up the transmission but the shock went through it and sheared off the motor pinion on the bosch. We put a new motor in and used it the entire season and post season with no signs of wear on the dog or dog mates. With generation 2 having the dog mate milled into the steel gear it looks to be even stronger. My 'non- expert' opinion is that it is oversized for the loads that are being applied to it by our motors in the kit and for its limited use in a FIRST season it works spectacularly.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 21-12-2003, 21:36
Along with the whitepapers from the Technokats' 2002 and 2003 transmissions, here's a picture of team 716's implementation of this type of "dog" shifting mechanism:
http://www.chiefdelphi.com/forums/pi...&quiet=Verbose
Unread 22-12-2003, 15:12
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
... Any engineering drawings available? Sketches? More importantly, equations!
Dave,
The TechnoKats/Andy Baker white paper (referenced above) is probably the best thing you will find to help explain this. If you still need any help with visualization please email me. I can try to put together some additional 3-d CAD views and/or animation of how this shifting arrangement works.
Good Luck!
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 22-12-2003, 15:26
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
We have not seen any wear after the three off-season competitions we ran with the square dogs. In fact the shifting seemed to get easier the more we ran the gearboxes. The square 'dog' is a nominal size, ie 1.25" square, while its mating hole is .004" larger, ie 1.254" square. This gives the needed clearance for the dog to fall into the hole. The corners do not mesh exactly, mostly clearance; the force is applied at a point similiar to a box wrench on a nut.
BTW we do not have any speed matching when we shift. The drivers pull a trigger to shift up and let go to shift down. Shifting down while running at high speed is not good for the gearbox just as it is not good for your father's car
Andy Brockway
Team 716, The Who'sCTEKS
Shifting Gears MBosompra Technical Discussion 71 23-07-2004 02:49
gear shifting Stephen Kowski Motors 19 30-03-2003 21:33
Junkyard Dogs NeO_Weapon General Forum 6 13-04-2002 22:59
Shifting Gears -- Anton Abaya Technical Discussion 26 22-01-2002 21:49
Visteon to leave teams to the dogs? nwagers Rumor Mill 6 24-10-2001 10:56
