Go to Post The one thing that no one ever list in scouting but is one of the most important factors is reliability. I don't care if the robot scores a hundred balls a match if I can't count on you being out there for the next three because it's a fragile as china. - Koko Ed [more]
Go Back   Chief Delphi > Technical > IT / Communications
View Poll Results: What resolution do you use on your monitor?
640 X 480 1 1.19%
800 X 600 6 7.14%
1024 X 768 35 41.67%
1280 X 1024 29 34.52%
1600 X 1024 3 3.57%
1600 X 1200 10 11.90%
Voters: 84. You may not vote on this poll
Unread 08-12-2003, 11:50
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Re: What resolution do you use on your monitor?
Originally Posted by Coffeeism
No one uses larger than 1600 x 1200??
I occasionaly use 2048x1536 and my second monitor at 1280x768. It's kinda hard to look at, but I only use it while I'm coding or somthing. I keep it at 1600x1200 with my second monitor off most of the time.
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
White Paper Discuss: Increasing A/D Resolution Using Noise CD47-Bot Extra Discussion 7 12-10-2004 09:26
What size monitor do you use? Elgin Clock IT / Communications 30 10-03-2004 16:53
DNS resolution mixup. evulish CD Forum Support 2 14-11-2002 23:40
High resolution FIRST logo thedillybar General Forum 4 16-03-2002 19:09
VB Program to monitor robot variables DanL Programming 7 15-02-2002 22:35
