Go to Post Bottom line: hobbiests, hackers, and tinkerers can fiddle with something and make it work. Engineers are people who [b]engineer[/b] solutions to problems. - Dave Flowerday [more]
Unread 08-12-2003, 18:03
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: press fitting
Also be aware that to successfully press fit a bearing will depend on the size of the hole into which you are pressing the bearing (or axle or shaft or whatever), the ratio between the hole diameter and the bearing/shaft diameter, and the materials being pressed together. All these elements are inter-related, and have to be considered.
Press fitting works by forcing a too-large peg into a too-small hole. To fit, either the peg, or the hole, or both, have to distort. That distortion generates huge friction forces between the parts, and they become "frozen" together (up to a point). The combined part can then withstand significant torques without moving relative to each other.
But how big should the "peg" be, or how small should the "hole" be, to make this happen? There is not a single answer to this. If one part is plastic and the other steel, then you would get a significantly different amount of distortion (higher) and resulting torque resistance (lower) than if both parts were steel. You have to calculate what size you want the "peg" to be after pressing, and how much the materials are going to distort, and from there solve backwards to figure our how large the original peg and hole should be to get what you want.
So it is not just a case of "drill the hole one size under and jam it in there." But, fortunately, a lot of the work has already been done for you. For most of the type of problems we are going to have with FIRST robots, you just need to identify the materials you are using and the size of the "peg," and then look up the reference tables in Machinery's Handbook or a similar publication. For simple cylindrical bearings as are mentioned above, this page gives a very good set of general answers.
There is a nice, fairly straightforward description of how this all works and the steps for properly press fitting bearings (including cartoons!) in the Installation Guide for Drill Jig Bearings. If you want to see a more detailed explanation of what is going on, check out this description in The Engineers Toolbox (which is a great resource you should know about anyway).
-dave
26 days to go!!!
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
Bosch Pinion JamesJones Motors 18 23-02-2003 00:20
SCRRF Press Releases Redhead Jokes Southern California Regional Robotics Forum 0 25-11-2002 15:07
Can a student Coach press the Stop Button archiver 2001 3 24-06-2002 02:39
need help writing a press release archiver 2001 1 23-06-2002 22:49
