Go to Post OK, I may have heavily influenced their decision, but I would never kill a mentor for not choosing an event I was planning... maim maybe, but never kill! :D - KathieK [more]
Unread 09-12-2003, 00:38
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Re: Shifting Gears
Originally Posted by Rickertsen2
That said i agree with previous posts, which state that the benefits of shifting should be carefully weighed against its disadvantages. As hard as it may be, decisions should be made not on emotion, but rather objective analysis and common sense. One thing is see all to often is something which is done merely because it is cool.
Absolutely correct. However, I think the past two years have really demanded a hearty drive train. See below.
>1 motor per side
If weight permits and current is not an issue, i see no reason not to use multiple motors on each side. There are 2 advantages i see in using multiple motors. First and most obvious, you get more power to work with. Depending on how your drivetrain is designed this can translate into more speed or greater acceleration and pushing power.
To clarify, if you are referring to the part of my previous post where I brought up using multiple motors (which you very well may not be), I'd just like to clarify that I believe that multiple motors on a shifting transmission is unnecessary. However, I whole heartedly believe that it's very practical and essentially required to have multiple pairs of motors if you do not have a way to change your gear ratios.
I would fight to the tooth (with numbers of course!) that you can not have a robot that is both competitively fast and competitively strong using only one pair of drill motors or the chips without a mulit-ratio transmission.
Perhaps that'd be a post for later.
Regional & Division winners, did you shift gears or not? DougHogg Technical Discussion 34 02-05-2003 16:10
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
gears....? archiver 2000 16 23-06-2002 22:58
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
