Go to Post "I need the adjustable hammer" "You mean that wren-" "No, it's a hammer" - Karibou [more]
Unread 12-02-2002, 23:31
Mike375's Avatar
Mike375 Mike375 is offline
#0375 (Robotic Plague)
Mike375 will become famous soon enough
Send a message via AIM to Mike375
Question Gamepad Controller
My team wants to use a Logitech Gamepad as a way of controlling some of our robot's functions, but I am having trouble writing a program to do so. My main problem is I can't find any resource online where I can find out the variable name of the buttons on the controller. I was able to get some operations working by declaring p3_y and p3_x, but I really need to find out the other buttons' names. If anyone knows of any source where I can find this, your help would be greatly appreciated.
Last Week Sleep Deprived FIRST freak,
Mike
Unread 13-02-2002, 00:09
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
You can do it the "fun" way...
Take the sucker apart and see what's inside. Use a multimeter to find what goes where. A gamepad probabaly only uses switches...
Unread 13-02-2002, 11:48
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Yes, that is the best way. However, it probably will take more time to figure it out then it is worth.
Unread 13-02-2002, 11:57
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Me and my friend were talking about using the GameCube controller and hooking it up so I can use it. It is ergonomicaly correct and has pressure sensitive buttions (L & R Buttons) It also has two controll sticks.
Unread 13-02-2002, 12:49
CaptainPlaid's Avatar
CaptainPlaid CaptainPlaid is offline
#0314 (Megatron Oracles "Big MO")
CaptainPlaid is an unknown quantity at this point
You might consider writing to Gravis and asking them for a pinout. I did this for some other CH joysticks and got a pretty fast response. Otherwise a multimeter will be the way to go.
I have not failed. I have just found 10,000 ways that won't work.
Thomas Edison
Unread 13-02-2002, 13:15
FRC Key Volunteer Trainer
AKA: CrazyNate
As nice of an idea as this sounds, it's not allowed. The AHL says only 15-pin joysticks/gamepads/etc. And the ruling on no USB to 15 pin adaptors would also apply to a GC to 15 pin adaptor, as it would involve custom electronics on the OI side to convert the signal, which is the same reason they're disallowing converteres from USB.
Nate Smith
nsmith@smythsoft.com
Unread 13-02-2002, 18:35
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
I dont have a good understanding of the OI rules, but couldnt you take apart a gamecube controller and run wires directly to the parts inside? Bypass whatever components convert it into the input the gamecube accepts.
Unread 13-02-2002, 20:34
Greg McCoy's Avatar
boiler up!
I think so, if you really want to destroy a Game Cube controller. I think there are no restrictions on where you get your buttons and switches from, other then it has to plug into that 15-pin standard joystick port.
I would take out all of the electronics in there except for the buttons, get an old 15-pin cable and cut off one end connector, and replace the original Game Cube connector with it so you can wire it up nicely.
Happy desoldering
Unread 14-02-2002, 00:43
You should realize that even if a joystick has a 15 pin gameport connector, it may not be workeable, even with re-wiring.
I know the new microsoft gamebads use a serial data stream, and I'd bet that a lot of others do too. I've never seen a game cube controller, but if it is anything like a n64 controller, it wouldn't work either.
Good luck, and hope it works out!
Unread 14-02-2002, 01:09
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
I was contemplating trying to get an old MS Sidewinder Precision Pro to work with the OI, but when I couldn't find any information about the joystick technically, and then when I found out that its input is done in software/drivers, I deserted the idea entirely...
I'd still like to get some sort of modified input for the control system, perhaps going to a store and getting a cheap-o joystick or two is the answer...
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 14-02-2002, 08:45
Don't go too 'cheap-o' on joysticks (if you can find a choice). I bought some, and found that the resistance did not start at the same value, did not stop at the same value (as the CH). and the composistion of the resistance was so bad that it would change as the OI read the value. The spring-return-to-neutral, didn't, at least, not consistently.
The CH sticks are really quite good !
Unread 14-02-2002, 08:53
#0588 (Team 588)
Even with controllers that do use digital outputs, they (probably) still have to get inputs from buttons or variable resistors, just like the flightsticks. You could just wire directly into those. But, the analog sources may not have the same resistance as the flightsticks, so I dont know if it will work. It would be fun to play with a console controller. I think I will invest in one in the off season.
Unread 16-02-2002, 21:52
GhettoTech GhettoTech is offline
#0300 (Ghetto Techs)
GhettoTech is an unknown quantity at this point
Send a message via AIM to GhettoTech
www.innovationfirst.com
FIRST Robotics
Control System User Manual
Pages 14 through 17 tell which pins are digital or anolog inputs, and the names of the variables in the program that are responsible for storing the data.
Unread 05-03-2002, 21:20
Mark Hamilton's Avatar
Mark Hamilton Mark Hamilton is offline
Belphegor made me do it.
#0108 (SigmaC@t)
Mark Hamilton will become famous soon enough
Send a message via ICQ to Mark Hamilton Send a message via AIM to Mark Hamilton
The FIRST mailing list fielded a question regarding convertors /and or controller modification. The answer was no convertors are not allowed, and no modifying the controller itself(including building your own connector using the switches). This ruined some plans of mine for the coolest(although completely impractical) controller ever. I may still build it just for fun though. (a hint:think no hands)
Retired member of Team 108
C controller Rorschach Kit & Additional Hardware 1 29-10-2003 19:21
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Visibility of Robot Controller and Reset Button Tracy Rules/Strategy 1 17-02-2003 07:36
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
visibility of robot controller? davidzhang Rules/Strategy 5 26-01-2003 01:11
