Go to Post Adaptability is the key folks. Your job will not be the same 10 years from now (when I retire), or 20 years or 30 years from now. The tools and systems you use will change, and you must be able to adapt along with them. - Bill Moore [more]
Unread 10-12-2003, 07:02
AlphaOmega870 AlphaOmega870 is offline
AKA: Mike
#0870 (Southold RICE)
AlphaOmega870 is an unknown quantity at this point
Send a message via AIM to AlphaOmega870
EDU robot programming
How would I go about changing the default program from single joy stick control to two joy stick control?
Unread 10-12-2003, 09:15
Re: EDU robot programming
In 1-joystick drive the code mixes the x/y on the one joystick. For 2-joystick drive you just use the y axis on each of 2 joysticks.
Change the following lines in user_routines.c at the top of Default_Routine to get rid of the mixed result and just use the PWM inputs directly.
Original code (get rid of the mixing):
pwm01 = pwm03 = Limit_Mix(2000 + PWM_in1 + PWM_in2 - 127); /* LEFT WHEELS */
pwm02 = pwm04 = Limit_Mix(2000 + PWM_in2 - PWM_in1 + 127); /* RIGHT WHEELS */
pwm01 = pwm03 = 255 - pwm01; /* reverse direction of left side */
New code (just :
pwm01 = pwm03 = 255 - PWM_in2; /* LEFT WHEELS - reverse direction of left side */
pwm02 = pwm04 = PWM_in4; /* RIGHT WHEELS */
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
Robot Programming Game Brandon Martus Chit-Chat 3 10-09-2001 23:37
