Re: Nitinol actuators
Actually, by that reasoning, you could use it if you managed to find a way to heat it with legal materials (not as a conductor of electricity, but of heat)...let's say, stall a drill motor, and have it dump about 450 W into that little wire. That ought to do it.
![]() (No, don't do this.) Unfortunately, it's a Ni-Ti alloy, and Ti is prohibited as an exotic material. Though they don't specifically state that alloys of exotic materials are prohibited, that's probably implicit in the rule. |
Yeah, Nc-Ti alloy is against the rules. Last year i wanted to use some thermoplastic memory wire as a structuaral aid that was based on the same alloy. Pretty neat stuff too.
Now i just give it away as gifts. |
This material barely is covered by the rules as it is so far outside anything that has been covered in the rulebook. If I was asked to rule, my first response (and simplest) is that the wire is not a specified wire size (minimum) for use on the robot. Even if insulated by teflon tubing, it still poses a hazard albeit a slight one. It would be interesting to experiment with a speed controller to vary the heating/contraction distances though.
Another issue may be the voltages that are usually applied to them, I rember when I built an stakito (sp) robot that used theise it reccomended around 3v, (9 was waaay too much applied directly to it, it would nearly jump but dident last very long) and when it is used in robotics I seem to rember that you apply an higher voltage for a very short time to get it to contract then lower the voltage to keep it hot and contracted.... such as 3v to start then lower to 1v in about .5 sec or so. While resistors are allowed in the materials list, they are only allowd in the custom boards that can only attach to the sensor inputs or serial port of the rc, not inline with the power. Altho like AL said, you may be able to use an speed controller to do this with PWM.
We were going to use some nichrome (spelling) wire last year to burn through cord to release a spring mechanism. We got it working really well too. We even showed videos to FIRST of exactly what it did and how much smoke it produced and how we would contain the smoke and make sure there was no chance of fire, but they would not let us use it. It still is really cool stuff to play with though.
Al |
