#7
Re: The 4 Big Questions!
Oh oh, let me try!
Question #1: What is the object? (i.e. Balls, Bins, Tubes, Floppies...) Balls, but probably something we havent used, like balls 1/2 way filled with water, or sand, or just weighted (I know water-filled balls have been used, I think) Question #2: What is the goal? (i.e. Large moving tower, puck, goal post...) A Large Central Column. There are 2-4 (I haven't made up my mind yet ) " deposits" or slots for balls to go in, and there are triggers around the field which drop out the floor of a deposit, making all the balls fall to the bottom level of the column. Balls in the top are multipliers, balls in the bottom are your base. There are openings on 2 sides of the base but they are only so high, so it's tricky to try and get your single points out to attempt to multiply them.Question #3: What is the special playing field surface trait? (i.e. Ramp, Water, Corn...) Mainly, the column. The sides are made from a more spread-out mesh, that is strong, so bots can climb on it. Also, on the 2 sides around the column, there are 2 small "speedbump" type ramps. Question #4: What will be the most controversial rule? Hmm. I think that being allowed to block switches that dump the deposits and blocking the top of deposits would get controversial. Oh and the game's called "Column Crisis" |
| How big will FIRST ever get? | Raul | General Forum | 41 | 26-10-2004 10:45 |
| New member, new team, questions. | Frank(Aflak) | General Forum | 21 | 14-12-2002 06:59 |
| Curie Division Robots information... (not complete) | archiver | 2001 | 3 | 24-06-2002 03:13 |
| Team 188 Pictures - four big balls anyone? | archiver | 2001 | 6 | 24-06-2002 01:03 |
| rules questions... | archiver | 2001 | 5 | 23-06-2002 22:40 |
