Re: Two-Speed Chassis
If a team were to put tread material on the "low speed" wheels, similar to the design from which this, um, monster (for lack of better word
) came from.If you did that, it'd enable you (I think) to mount the stair, and then the tread material would pull the robot up as you powered the motors forward. Once you're up, pop back up into high speed, and you're good to go. Similarly, to get down, you could drive the low speed wheels up to the ledge in low speed (obviously would require a high amount of driver control, or some sort of feedback system), pop "up" into high speed, but since the high speed front wheels are over the air, they fall back down, hit the ground, and you can smoothly transition back down to the lower area (or much more so that just driving off and hoping you land without breaking anything). The only problem I can see here is, well, Krass's designs do tend to be a bit more complicated to build than they look on paper (a problem for teams with less materials, but well within range of any midsized team who has a decent supply of robot-building parts). But, if you can get it working, it's usually a pretty formidable robot. And not to discourage newer teams (is 810 still considered a newer team?), but this is a design that you may want to hold off a bit on, at least until you're sure of your capabilities, because yes, it will perform, but it will take you a long time to build this. Otherwise, I'm glad to see that "El Toro" may now have a distant cousin/decendent/etc, and I really hope a team does go with this design this year, because it is quite an amazing looking robot. Keep up the good work Krass . |
Beautiful... I love robots that have different sets of wheels to shift gears. But someone has to be a skeptic... how much does it weigh? We tried a similar thing (with four motors and two sets of four wheels) in 2002 but had to take off two wheels, two motors, and a whole component from our robot to be able to get underweight. I guess if we had designed with weight in mind from the beginning we would have had much better success though (a subtle hint to any young impressionable team members out there!!). Your design looks much more weight efficient. Did you do mass analysis with Solidworks? Hopefully I'll somehow get to see the finished bot in person (or at least you can post some pics at the end of build season)!
Good luck - Patrick |
question... how much torque would you have when you are driving in low speed configuration...and how long would it take you to get to high speed configuration from low speed...??? should i guess about probably a sec or two... since you are using pneumatics to switch....?
the design looks awesome... Last edited by Arefin Bari : 10-12-2003 at 21:33. |
I love it as a drive train! its a great idea, Seems like you would be cramped for space and/or weight but still a cool idea.
There 101 different directions you could go with an idea like that to fit your own individual robot each year. Keep up the good work. |
I saw a robot that did this at the SoCal regional last year, but I do not recall the team number.
What is the height of the crossmember when raised? How much is the base raised when in highspeed mode? It appears from the images that it isn't that high with plenty of room around it to place things. However, it does appear to severly limit placement of manipulators low to the ground, which has traditionaly been part of the game in some way. Pretty. Wetzel ~~~~~~~~~~~ Hurray for shared innovation. |
Saw them at IRI. Heck of a bot. |
#7
In terms of actually transferring power to the two sets of drive wheels, are you going to be driving the low-speed wheels directly from the gearboxes, and then running chains to the high speed wheels? (No driveshafts appear in the drawings.)
Are you going to have enough room to run sprockets and chain (with any necessary ratio) inside the pivoting triangular frames (the red parts with wheels attached)? Also, both sets--front and back--of low-speed wheels need to be powered. Does this imply that you'll be running a drive chain inside of the C-channel, from shaft to shaft? If so, it looks like you'll be limited to relatively small sprockets (max 2" to 2.5"), which, as we found out last year, can eat chain, given a powerful drive system.... With what appears to be 1/8" plate in the centre of the chassis, are you concerned at all about flexing/buckling (due to collisions, or the 200-lb pneumatic fury of those pistons)? A crossmember of some sort would surely minimize this. (Maybe that was going to be added later, in the final version of the design?) Lastly, will those 1/2" rods that support the entire wheel assembly on both sides be enough to handle the stresses of driving? If the field is flat, you might be just fine, but with something like last year's ramp, they may prove insufficient for the bumpy ride that the robot might endure. (The bolt holes in the C-channel where these attach are going to be rather stressed if the robot falls even a few inches.) OK, that's enough constructive criticism for now...otherwise, though, it is really quite an interesting design. (And very nicely executed.) Last edited by Tristan Lall : 11-12-2003 at 02:40. |
#8
I appreciate everyone's feedback so far. I promise to answer all the questions you've asked as soon as I can. I think I need to do some math again since I can't find the calculations I did for output speed and output torque, particularly.
Thanks! |
#9
Nice design.
Might I suggest that two of the omniwheels (on one end) be changed to regular high friction material. This will give you much more control. With four omniwheels, it can slide around too easily, especially if it gets bumped. Raul |
| "Automatic Transmission" | Madison | Technical Discussion | 70 | 24-11-2003 09:03 |
| speed controllers & circuit breakers | deuceswild | Electrical | 2 | 15-01-2003 14:46 |
| Power, speed, and torque... AGH | Gui Cavalcanti | Technical Discussion | 5 | 10-11-2002 19:02 |
| Calibrating speed controllers and joysticks | thedillybar | Technical Discussion | 4 | 11-02-2002 13:24 |
| Speed Controller/PWM problems.... | Clark Gilbert | Technical Discussion | 8 | 08-01-2002 00:14 |
