Go to Post To quote Dylan, "When you aint got nothing, you got nothing to lose". - KenWittlief [more]
Unread 10-12-2003, 21:26
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: Two-Speed Chassis
question... how much torque would you have when you are driving in low speed configuration...and how long would it take you to get to high speed configuration from low speed...??? should i guess about probably a sec or two... since you are using pneumatics to switch....?
the design looks awesome...
Unread 10-12-2003, 23:03
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
I love it as a drive train! its a great idea, Seems like you would be cramped for space and/or weight but still a cool idea.
There 101 different directions you could go with an idea like that to fit your own individual robot each year.
Keep up the good work.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 11-12-2003, 01:27
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
I saw a robot that did this at the SoCal regional last year, but I do not recall the team number.
What is the height of the crossmember when raised? How much is the base raised when in highspeed mode? It appears from the images that it isn't that high with plenty of room around it to place things.
However, it does appear to severly limit placement of manipulators low to the ground, which has traditionaly been part of the game in some way.
Pretty.
Wetzel
Hurray for shared innovation.
Unread 11-12-2003, 01:43
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
That would be 980.
Saw them at IRI.
Heck of a bot.
Unread 11-12-2003, 02:22
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
In terms of actually transferring power to the two sets of drive wheels, are you going to be driving the low-speed wheels directly from the gearboxes, and then running chains to the high speed wheels? (No driveshafts appear in the drawings.)
Are you going to have enough room to run sprockets and chain (with any necessary ratio) inside the pivoting triangular frames (the red parts with wheels attached)?
Also, both sets--front and back--of low-speed wheels need to be powered. Does this imply that you'll be running a drive chain inside of the C-channel, from shaft to shaft? If so, it looks like you'll be limited to relatively small sprockets (max 2" to 2.5"), which, as we found out last year, can eat chain, given a powerful drive system....
With what appears to be 1/8" plate in the centre of the chassis, are you concerned at all about flexing/buckling (due to collisions, or the 200-lb pneumatic fury of those pistons)? A crossmember of some sort would surely minimize this. (Maybe that was going to be added later, in the final version of the design?)
Lastly, will those 1/2" rods that support the entire wheel assembly on both sides be enough to handle the stresses of driving? If the field is flat, you might be just fine, but with something like last year's ramp, they may prove insufficient for the bumpy ride that the robot might endure. (The bolt holes in the C-channel where these attach are going to be rather stressed if the robot falls even a few inches.)
OK, that's enough constructive criticism for now...otherwise, though, it is really quite an interesting design. (And very nicely executed.)
Unread 11-12-2003, 14:14
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I appreciate everyone's feedback so far. I promise to answer all the questions you've asked as soon as I can. I think I need to do some math again since I can't find the calculations I did for output speed and output torque, particularly.
Thanks!
--Madison--
...down at the Ozdust!
Unread 13-12-2003, 11:41
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Nice design.
Might I suggest that two of the omniwheels (on one end) be changed to regular high friction material. This will give you much more control. With four omniwheels, it can slide around too easily, especially if it gets bumped.
Raul
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
speed controllers & circuit breakers deuceswild Electrical 2 15-01-2003 14:46
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
Speed Controller/PWM problems.... Clark Gilbert Technical Discussion 8 08-01-2002 00:14
