Go to Post The biggest fallacy in FIRST is the belief we are just a bunch of different teams. We are ONE BIG TEAM with a lot of sub teams for the purpose of competition. - Al Skierkiewicz [more]
Unread 11-12-2003, 11:38
edomus's Avatar
edomus edomus is offline
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
edomus is on a distinguished road
Send a message via AIM to edomus
solid works help needed
I imported extrustion from www.firstcadlibary.com into solidworks. Is there a way to elongate a part once it is extruded or do I have to mate all of the small parts together to get the length that I want. Thanks
2004 National Finalists with 469 and 868
2004 Gallileo champions and #1 seed
  • Delphi "Driving tommarows technology" -philly 2004
  • 8th seed philly 2004
  • 58/58 at annapolis 2004 (like the improvement?)
  • Philadelphia Alliance Regional Winner!-2003
  • 7th seed Philly 2003
  • Rookie all star philly 2003
  • semi finalist Pitt 2003
  • picked 3rd in pitt 2003
  • Seeded 17(curie) at nats 2003
Unread 11-12-2003, 12:14
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: solid works help needed
To really answer this question I would need to actully know what your background and/or experience is in Solidworks, and what the part actually was..
But.. to take a shot in the dark so to speak, I am guessing that you have a part you brought in and it came in at a fixed length and you would like to make it longer (or shorter - that will work too).
What you want to do is click on the end of the part, and start a new sketch on that plane.
Then you can use the "convert entities" button in SolidWorks (looks like a little cube with all black lines except for one red line - it is on the "sketch tools" toolbar in case you don't have that showing) and select all the individual (or one large if that is the case) lines that make up the profile.
What that allows you to do is then, use that profile as your "new" sketch.
And then all you have to do is either make an cut-extrude to shorten it, or a boss-extrude to lengthen the part.
Hope this helps.
Unread 11-12-2003, 14:06
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Or, on the original Extrude feature, you can right-click on it and choose Edit Definition -- then change the extrude length to be whatever you need.
Be aware that, at least for the extrusion from FIRSTCadLibrary.com that I've used, the sketch has *no* constraints built in and isn't square. It'd be wise to go in and add constraints to that sketch first before you do anything further.
--Madison--
...down at the Ozdust!
Unread 11-12-2003, 17:41
Yes, as M. Krass said, there may be problems with the lack of constraints when you make the new sketch or even work with the old one, so just keep putting constraints and dimensions until every line is black, Because as my professor kept telling us "Black is beautiful"
I was going to say that too, but most of the extrusions and parts I have brought into SolidWorks from firstcadlibrary.com have all been considered "imported parts" and not able to be easily edited. This is probably the reason for the original question... If it were just as simple as to modify the length of the original feature in a dialog box of some kind, I don't think he would be asking what he is asking - but then again, you never know!
Unread 11-12-2003, 18:32
Madison's Avatar
FRC #0488 (Xbot)
Whenever I've opened IGES-format files in Solidworks (2003), it's automatically proceeded with feature recognition and made the part editable. It's a part of Featureworks, which may or may not be included with Solidworks -- I'm honestly not sure.
--Madison--
Unread 12-12-2003, 21:26
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
With IGES format I think it depends on how complex the part is.
Extrusion is a pretty simple part and very important- you would probably be happier redrawing it in SW (unless you enjoy fixing hundreds of broken mates : ) ). You can use the measure function to get dimensions and (as stated above) the convert entities to get profiles. What I would do is project the cross-section profile onto a new sketch using convert entities, copy that sketch, then paste it into a new part file and extrude it.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Chamionship Qualification - feedback needed ASAP! dlavery General Forum 97 11-10-2003 07:17
The Grand FIRST team.. programmers and others needed randomperson Programming 0 31-05-2003 23:46
solid edge solid works ceileachair Inventor 1 21-01-2003 22:03
solid edge ver 12 ceileachair Inventor 1 19-01-2003 21:15
High School Curriculum needed archiver 2000 0 24-06-2002 00:29
