Go to Post When FIRST teams are as numerous and as well supported as basketball teams, we will know that our culture is preparing young people to compete in the 21 st century and we are spending our 2 million minutes wisely. - N7UJJ [more]
Unread 11-12-2003, 14:08
Re: Nitinol actuators
This material barely is covered by the rules as it is so far outside anything that has been covered in the rulebook. If I was asked to rule, my first response (and simplest) is that the wire is not a specified wire size (minimum) for use on the robot. Even if insulated by teflon tubing, it still poses a hazard albeit a slight one. It would be interesting to experiment with a speed controller to vary the heating/contraction distances though.
Unread 16-12-2003, 12:18
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Another issue may be the voltages that are usually applied to them, I rember when I built an stakito (sp) robot that used theise it reccomended around 3v, (9 was waaay too much applied directly to it, it would nearly jump but dident last very long) and when it is used in robotics I seem to rember that you apply an higher voltage for a very short time to get it to contract then lower the voltage to keep it hot and contracted.... such as 3v to start then lower to 1v in about .5 sec or so. While resistors are allowed in the materials list, they are only allowd in the custom boards that can only attach to the sensor inputs or serial port of the rc, not inline with the power. Altho like AL said, you may be able to use an speed controller to do this with PWM.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 16-12-2003, 12:30
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We were going to use some nichrome (spelling) wire last year to burn through cord to release a spring mechanism. We got it working really well too. We even showed videos to FIRST of exactly what it did and how much smoke it produced and how we would contain the smoke and make sure there was no chance of fire, but they would not let us use it. It still is really cool stuff to play with though.
Unread 16-12-2003, 14:04
Nichrome wire is used in heating coils for toasters and irons. Although it is great for those applications, it does present a fire hazard and it is considered exposed wiring since it is conductive. A draw back is that it is fragile when heated if not well supported. Just look into the top of a toaster and you will see what I mean.
