Does anyone have either a CAD model of the Bosch Drill motor or its dimensions? Either would be greatly appreciated.
Thanks, Ryan |
Re: Bosch Drill Motor
Go to www.firstcadlibrary.com
I should have a model posted shortly of last year's drill motor along with some other new models and some IGES translations - probably by Monday morning. |
Actually it's not there yet; Ed Sparks said he was going to make one in the near future. He does have a CAD of the pinion of that motor, though (10 tooth, 0.7 module, 20° pressure angle).
Edit: Speak of the devil--he beat me to it.... |
The new Bosch motor is posted in the Motors Library. The pinion gear will be posted in a day or so. I'm working on an i-Gear model that will generate just about any spur gear you would want with optional hub and key.
Do you have a general date that you will finish the i-Gear model? |
#7
Thanks for putting the motor up on the library. That helped us a lot.
| drill motor mounts- again | Jeff Sharpe | Motors | 6 | 07-04-2003 23:20 |
| Replacement Bosch drill motor assembly | james700 | Motors | 3 | 31-01-2003 21:08 |
| A new record for breaking a drill motor | ZacharyD | Technical Discussion | 23 | 16-01-2003 16:58 |
| Bosch Drill Motor CAD Files | Madison | Inventor | 10 | 09-12-2001 00:14 |
| Drill Motor and FP Motor Shaft Diameters | Andy Baker | Motors | 4 | 11-06-2001 20:12 |
