Go to Post Many of us are engineers who value precision and accuracy in communication. Words mean things. - Alan Anderson [more]
Unread 28-01-2002, 18:27
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
Wiring custom toggle switches into operator interface
Hey guys, I want to basically wire custom toggle switches (i.e. SPST's) into one of the ports on the operator interface, so that when you flip one switch, say, pin 3 returns a 1. I did a quick and dirty (but interactive ) flash movie of basically what we want - http://nervae.phenominet.com/first/whatwewant.html. Doing the wiring isn't exactly hard, just knowing how to wire it is a trick.
I'm not sure how these ports work, but I'm guessing each pin is some kind of 'mini-circuit' that if closed returns a 1 and if open returns a 0, meaning one of the pins is the power and the others are 'circuit pins'? ...or am I completely ouyt there? Check out my flash movie to see basically what we want to do. Any links or explinations on how to wire it would be helpful.
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 28-01-2002, 19:05
FRC Key Volunteer Trainer
AKA: CrazyNate
Hope this Helps
Basically, what you're looking at is something like this...
In the simplest form, a digital input on the OI could be a wire running between a signal pin and a ground pin. In that case, you would always have a value of 1. So, putting a switch in between the two pins lets you control the value(off/open = 0, on/closed=1)
Nate Smith
nsmith@smythsoft.com
Unread 28-01-2002, 19:20
Crusty Mentor
FRC #0097
Hmm, electrics isn't exactly my thing - atleast word-wise it isn't. I think I understand what you're talking about, but can you draw up a small dirty diagram?
Also, in the case of the operator interface, where does the power come from? Does it come from one of the pins? If no, how much power do we use?
Dan L
Team 97 Mentor
Unread 28-01-2002, 19:42
Crusty Mentor
FRC #0097
Okay, I was thinking about it, and through the powers of god, I came up with this diagram. Is this right? Also, what are the voltages, and whats the ohm rating of the resistor that we should use?
Dan L
Team 97 Mentor
Unread 28-01-2002, 21:05
RebAl's Avatar
RebAl RebAl is offline
ISee It When I Believe It
None #0329 (The R.A.I.D.)
RebAl will become famous soon enough
Send a message via ICQ to RebAl Send a message via AIM to RebAl
here are the pinouts for port 3:
(PIN)
(2) Joystick Trigger Switch Digital (bit) p3_sw_trig Relay 3 Forward SW05 [5]
(7) Joystick Thumb Switch Digital (bit) p3_sw_top Relay 3 Reverse SW06 [5]
(10) Aux Switch1 Digital (bit) p3_sw_aux1 Relay 6 Forward SW07 [5]
(14) Aux Switch2 Digital (bit) p3_sw_aux2 Relay 6 Reverse SW08 [5]
pin 4 and 12 are grounds
so if you want p3_sw_aux1 in the code (for example) to be 1, you wire a switch from pin 4(or 12) to pin 10 which is the imput, so basically for a switch to work you wire it from the pin you want to the switch then the switch to ground
so
pin 10 on oi----->switch------->ground
| The Switch |
| (SPST) ]
___________________
pin 10 ground
_______________________________________
and check out the control system manual at:
MANUAL
page14-17 has the pin-outs for the others
______________
hope this helps
Unread 28-01-2002, 21:08
RebAl's Avatar
that diagram did not come out well , try this:
Unread 28-01-2002, 23:52
Crusty Mentor
FRC #0097
Ahh, thanks, that makes everything clear, or so I hope. Thanks for the link - I was looking for that information (I was going to the "Operator Interface" link rather than the entire control systems link). Anyways, I think I have the electrics diagram right now that we know what pins do what, but then again, electrics isn't my strongest subject. Can you take a look and make sure it's right before I go and fry our OI? http://nervae.phenominet.com/first/whatwedo.html
Thanks for your help!
Dan L
Team 97 Mentor
Unread 29-01-2002, 07:26
RebAl's Avatar
That would be correct, if you need any more help im right in patchogue n.y., you can e-mail me here if you need anything else.
Unread 13-02-2002, 13:42
CaptainPlaid's Avatar
CaptainPlaid CaptainPlaid is offline
#0314 (Megatron Oracles "Big MO")
CaptainPlaid is an unknown quantity at this point
Nice animations. It really helped figure out what was going on. If you want do use more buttons you might consider using the y-cable on the control system. More info can be found in the White Pages.
I have not failed. I have just found 10,000 ways that won't work.
Thomas Edison
Unread 13-02-2002, 17:13
Ok, for those who did not get the message before...
Don't connect up to the input pins on the controller until you have investigated the input requirements of the controller on the Innovation First website. Damage to inputs (permanent, that is) can result and are not covered under the warranty. A simple pull up resistor with a switch is recommended for analog inputs acting as digital inputs. (i.e. ON/OFF) The Innovation First papers are much more descriptive than I can be here. Please read them before proceeding.
Good Luck All
Need help with custom switches archiver 2001 3 24-06-2002 00:35
Wiring Switches To the Operator Intrerface archiver 2000 2 23-06-2002 23:02
So what's in YOUR Custom Circuit this year? kmcclary Technical Discussion 7 10-04-2002 12:20
