Go to Post I wonder if the GDC had his extraordinary achievements in mind for the 2012 game. - MagiChau [more]
Unread 13-12-2003, 15:17
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Gears and Sprockets
I'm learning the Inventor 7 software and I've been working on drive models for this season. I've encountered a problem however, I cannot figure out how to make gears or sprockets. If anybody out there knows how I could do this could you please inform me.
Thank you
-Pat
Unread 13-12-2003, 16:22
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Re: Gears and Sprockets
Thank you
-Pat
Check out my i-Sprocket on FirstCadLibrary. I'm currently working on an i-Gear model to be published shortly.
Ed Sparks
MECH TECH FRC-3959
Unread 13-12-2003, 17:45
NateBot16 NateBot16 is offline
#0528 (Dark Knights)
NateBot16 is on a distinguished road
Send a message via AIM to NateBot16
Find the diameter of the sprocket between the teeth, and in between the teeth. Make a cricle the diameter of the distance inbetween the teeth, then extrude that to the thickness you need. Then put a skecth on that, and selcet the contuction line option (top right corner in the drop down menu), and make another circle the diameter of the larger distance, from tooth end to tooth end. Then make sketch on that, from the inside circle, to the constuction circle. You will need to make some measurements on the angle of the teeth and such, but one you have that, finish the sketch, and extrude the single tooth to the thickness you need. Then do a circular pattern, picking the number of teeth in the sprocket or gear. An bada bag a gear or sprocket. A note with sprockets, fillets are most likely going to be needed inbetween the bottoms of each tooth.
Hope that helps, if you have any questions, I'll be glad to help. I just finished sketching our teams new sprockets.
Unread 13-12-2003, 18:38
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Draw a slice of the gear/sproket (triangle with tooth profile on top), then circle pattern it.
Is there a reason to actually draw the teeth, besides cosmetic (not that cosmetic isnt important )? Why not just use cylindrical representations? You could still check for proper meshing and other conflicts and would save computer memory and CPU time... and the frustration that tends to come with tooth profiles.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
shafts, gears and wheels.... archiver 2001 13 24-06-2002 04:09
Attaching the Gears and sprockets to the shaft archiver 2001 2 23-06-2002 23:18
Are gears really this expensive? Anton Abaya Technical Discussion 2 13-01-2002 22:23
