Go to Post If you're the smartest person in the room, you're in the wrong room - Ian Curtis [more]
Unread 30-04-2003, 13:10
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: If you had made it out of steel . . . . .
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
this is true. I should have done homework instead.
Unread 30-04-2003, 22:08
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is online now
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Wow!... You deserve about 30 bazillion high fives right now.. that is the first multi-directional lego drive I've ever seen.. very, very nice. Now, I'd love to see a middle school team with something like that... heh a middle school lego team w/ a lego omni drive.. now that'll be the day...
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 30-04-2003, 22:15
#1067 (SLUH)
Hell, I understood the concept the first time I saw it and built it as soon as I realized that it may be possible in LEGO. The hard part was finding all the little peices. Middle schoolers (with proper support, encouragement, etc.) should be able to do that no problem.
The only problem is that the RCX only has three motor outs, so it wouldn't be able to do anything but drive around unless you were really clever and made some spring-loaded stuff.
Unread 30-04-2003, 23:44
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I've seen one before http://home.arcor.de/markus.matern/R...orm/index.html but you still deserve the high fives. Maybe not 30 bazillion but a bunch anyway.
Unread 01-05-2003, 13:09
#1067 (SLUH)
I remember seeing that drive base in the past, but I had forgotten about it. Mine was probably easier, but I bet his is more robust.
Too bad I don't have six of any big wheels. I could probably do something like that, though, and I might, if this one is having problems. I like my center column, though. heh. thanks for the link.
Unread 01-05-2003, 15:34
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
So... my question: how much power does a system like this have? Do you lose any power because of its triangular orientation?
Jeff Waegelin
Unread 01-05-2003, 16:05
Woa ! Now that's awesome too.. I wonder if there'd be some way to only run it w/ two motors.. like make one of those non-powered so it just slides w/ the others.. but then it wouldn't really be a versatile.. hmm....
Unread 01-05-2003, 18:27
El Jefe de 148
Given the complexity of such a system, I don't think that would work too well. To get the full flexiblity it offers, you need 3 motors. Besides, what would the advantage be in powering 2/3 of such a system, over just a standard 2WD system?
Jeff Waegelin
Unread 01-05-2003, 19:12
#1067 (SLUH)
if your wheels are good and the bearnings in them are efficient, no more power loss than your standard tank drive going straight.
What you have to remember, though, is that your 'real' speed will be higher than the speed a normal wheel would go for the same RPM, so you want to wheel spinning a little slower than you need . .
basically, the drive base is a gearing up, less power, more speed for the same shaft RPM.
otherwise, if your omni wheels are good, the only disadvantage is working with such a weird drive base and explaining it a million times to the curious.
Unread 02-05-2003, 17:47
rlowerr_1's Avatar
rlowerr_1 rlowerr_1 is offline
#0930 (M³)
rlowerr_1 is an unknown quantity at this point
Send a message via AIM to rlowerr_1
That has got to be one bumpy ride!
this has nothing to do with this topic but take a look at my lego copy machine!
http://www.brickshelf.com/cgi-bin/gallery.cgi?f=41114
Unread 02-05-2003, 20:57
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
Vectors. If you want to calculate force in one direction, you reduce the vectors into their components.
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Unread 13-12-2003, 16:36
#1067 (SLUH)
Re: pic: If you had made it out of steel . . . . .
actually, if you see the tech discussion forums I had a big argument with some guy about power loss in the killough.
With a triangular killough you do lose power because your motors fight each other, but in a quad wheel/square killough no power is lost.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
steel plate ........legal dimensions? archiver 2001 1 24-06-2002 00:32
To all the people who made new friends! kevinschnepp535 Championship Event 4 03-05-2002 12:13
Legality of steel tubing. newy Rules/Strategy 3 01-02-2002 09:16
