Go to Post I have always been of the opinion that if the mechanicals are making noise they are trying to talk to you. - Al Skierkiewicz [more]
Unread 13-02-2002, 19:40
Joelster Joelster is offline
#0758 (Roboticats)
Joelster is an unknown quantity at this point
Cool Arm Turning (1 button programming)
ok......i have asked several questions about the turning of the arm......slowly but surely with all of your help our control team has figured out a simple program to make the arm turn with ONE BUTTON!!!! Thanx for everyone's help and please reply here or pm me if you have any questions!!! Our team will be glad to help out. Here is the code for everyone who needs it
'------------- Tbar Turn -----------------
'-- #1 --
if logged = 1 then hopskipjump:
if count1 = 1 then skippy:
if p1_sw_top = 0 then out:
if p1_sw_top = 1 then in:
in:
relay1_fwd = 1
relay1_rev = 0
count1 = 1
goto hopskipjump:
out:
skippy:
if count1 = 0 then jumpy:
if p1_sw_top = 0 then outy:
if p1_sw_top = 1 then iny:
iny:
relay1_rev = 1
relay1_fwd = 0
count1 = 0
outy:
jumpy:
hopskipjump:
logged = p1_sw_top
Unread 13-02-2002, 19:53
OddOne OddOne is offline
OddOne is an unknown quantity at this point
Send a message via AIM to OddOne
That's sweet.
But why did you use outy: and jumpy:? Couldn't you use hopskipjump: instead since it goes to the same place? It would save your memory and processor from having to process those lines.
Mike
The "Odd" one
Unread 13-02-2002, 19:57
#0758 (Roboticats)
dont know
the one who programmed it decided to use those words for the heck of it
Unread 13-02-2002, 20:01
#0758 (Roboticats)
oh yah
The code works!!!! It doesnt need any editing if you just wanted to know!!!
Unread 13-02-2002, 21:35
758controls 758controls is offline
#0758 (Roboticats)
758controls is an unknown quantity at this point
Yeah.. Now that I look at it
Now that I look at it, it is the same address.. I don't think that they were the first time I wrote it .. but now that it has been edited..
Thanks.. I'll remove those two lines from the code.
I also probably wrote it that way because I'm use to nested "if" statements so I always want to end an "if" statement. I sure wish they would get away from using PBASIC as a programming language though, me and my team all hate it.
Balance while turning? sanddrag Dean Kamen's Inventions 8 26-09-2003 17:18
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
Controlling Arm travel - Limit Switch or Mechanical Stop? archiver 2001 8 23-06-2002 23:55
Correction for arm skyfw Programming 6 06-04-2002 21:59
telescoping arm & ten second rule Ben Mitchell Rules/Strategy 4 18-02-2002 21:37
