Go to Post When everyone is exactly even, who do you look up to for ideas and inspiration? - artdutra04 [more]
Unread 03-12-2003, 21:54
Jim Giacchi's Avatar
Jim Giacchi Jim Giacchi is offline
FRC #0041 (Robo-Warriors)
Jim Giacchi will become famous soon enoughJim Giacchi will become famous soon enough
Send a message via AIM to Jim Giacchi
Van Door Worm Gear
A project that im working on has an application that is perfect for the Van Door motors, however the team is a little concerned about the plastic gears inside the gearbox. Im pretty sure that teams in the past have replaced the internal gears with ones made of metal. I was wondering if anyone had any information on how they did this.
Thanks,
Jim Giacchi
Build first ask questions later.
Unread 04-12-2003, 07:47
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Re: Van Door Worm Gear
Jim,
I believe you will not have a problem with the plastic gear that drives the worm gear. We used these on our robot in 2000 and 2001 under constant heavy load (including shock loads) and never encountered any problems. Keep in mind that the engineers who designed this accounted for its strength characteristics under the max stall loads. So, unless your application will require some excessive shock loads, you should be OK.
I just thought of another potential problem with some plastics. They have a glass transition temperature (GTT) not to far below freezing. This means that they become brittle and will crack under minor shock loads when used in very cold environments. Some cast metals also behave this way. I know from experience that cast zinc start to become brittle at about 20 deg F.
Hope this helps.
Raul
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 04-12-2003, 14:39
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
We too have used the van door motors in some seriously high load situations (pull ups in 2000 for instance) and never had a problem with the motors. They work in cars for years, and probably are designed with a plastic that can get pretty cold, last thing the car companies want is people not being able to get out of the car just because its cold!
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 04-12-2003, 15:15
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Since these motors are actually used on Delphi Power Sliding Door applications and I work in the Advanced Development Group for the group that designs power sliding doors, I have some knowledge of this motor.
Raul's concern about cold is probably not an issue. We test down to -40 C with no problems.
I think your real problems will come if you are impact loading the teeth. In this case, you can bend the teeth pretty quickly.
So, if you are driving a long rigid arm and expect the arm to take a lot of hard wacks in directions that will give impact loads to drivetrain you are asking for trouble. Another way to give impact loads to the gear teeth is to run into a hard stop at high speeds (stalling the motor against a hard stop should not be a problem).
I have first hand knowledge of this failure mode. We used the power sliding door motor with great success over the years. BUT, one year we used it to lift ourselves on the puck. The mechanism was such that the drive link went over center at the bottom of travel so that we could stay up when power was removed. At the end of travel we had a hard stop. Basically every time we lifted ourselves, we ran the motor at full speed into a hard stop. We were eliminated from the competition due to failure of that gear. Tests after the Championships showed us that we could fail that gear in only a handful of lifts.
Keep this in mind and you will probably have no troubles.
Good Luck.
Joe J.
Unread 16-12-2003, 09:35
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Thanks,
Jim Giacchi
On a different subject, replacing this gear with a metal one in a competition would have been illegal for the past several years. All motors with integral gearboxes and the internals of the other motors were not modifiable.
The detachable gearboxes (drill motor, globe) were modifiable.
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
Drill motor gearBox question Dennis Hughes Motors 4 11-10-2001 07:11
