Go to Post No disclaimer on earth lets you disassociate yourself with your team or what you represent because you want to say something not particularly nice, but lets you be associated again when you want to say something to encourage others, etc. - Amanda Morrison [more]
Unread 07-12-2003, 09:46
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: "Cheap" Robot parts
Originally Posted by Adam Y.
Is that good or bad? Should the lubrication stay inside it or outside it?
Once an oil impregnated bearing gets too hot, the oil sorta "boils out" of the bearing, then the bearing dries up and it does not work as well. The hole gets a bit bigger and the bearing is shot. It is definitely not a good thing... you want the oil to stay inside the bearing material.
Andy B.
Unread 07-12-2003, 12:57
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
I guess I should have elaborated a little more on my suggestion to use a bronze bushing. You may get away with not using oil for some time when a bronze bushing is used for a steel (or maybe some other hard metal) shaft. But I know from experience that you must use additional oil if used for an aluminum shaft. And if you use an aluminum shaft with a bushing, you should try to stay away from using it for high RPM applications.
Raul
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 07-12-2003, 20:19
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Ok, here's a quick question guys. We took our pre-season vote to go ahead with my "standard" drive design (yay!)
But it was brought up that the idle shaft's bearings could be replaced with bronze bushings, at a cheaper cost.
I'll be honest here, I've never used bushings before. What's involved with them? From what I understand you need a housing block of sorts for them.
Anyway, I have 2 idle shafts. They dont spin, they provide support for the wheels and chassis. Would it be better to replace the bearings they are on with bushings?
Also, where can you find good, cheap bushings? I checked MSC and had trouble finding some.
I need 4 (one for each support point) and they need to be for 5/8 shaft (I think it's steel) and need an outside diameter no larger than 1 inch.
If someone could help me out, that'd be great. Currently, we have several 4-bolt flange bearings we're using, and they're around $26 each. So, having some of those trimmed off for bushings should help a bit, i'd suspect.
But I don't want to deal with this thing falling apart at competition. We want it to last.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 10-12-2003, 13:52
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: "Cheap" Robot parts
But it was brought up that the idle shaft's bearings could be replaced with bronze bushings, at a cheaper cost. I'll be honest here, I've never used bushings before. What's involved with them? From what I understand you need a housing block of sorts for them. Anyway, I have 2 idle shafts. They dont spin, they provide support for the wheels and chassis. Would it be better to replace the bearings they are on with bushings?
If they're not spinning at all... sure bushings... actually, you could probably just have them rest on whatever metal they're in between. However, I'd like to see a picture or a sketch (if possible) so see how these are "supporting" the wheels and chassis. Are they just spacers?
Also, where can you find good, cheap bushings? I checked MSC and had trouble finding some. I need 4 (one for each support point) and they need to be for 5/8 shaft (I think it's steel) and need an outside diameter no larger than 1 inch. If someone could help me out, that'd be great. Currently, we have several 4-bolt flange bearings we're using, and they're around $26 each. So, having some of those trimmed off for bushings should help a bit, i'd suspect. But I don't want to deal with this thing falling apart at competition. We want it to last.
Well, I think that your best bet for cheap bushings are McMaster-Carr or Endco. Here's a link for the exact bushings you're looking for.
Thrust Bushings:
http://www.mcmaster.com/asp/loadpage...995&catnum=109
Flanged Bushings:
http://www.mcmaster.com/asp/loadpage...996&catnum=109
Also, sometimes companies use bushing and bearing synonymously, so searching for bronze bearings can sometimes get you what you're looking for.
Let me know if you need anything else.
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 14-12-2003, 13:48
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
heres an idea i had this morning
seing as how the globe shaft only takes rotational loads it needs a bearing with a 1/4 ID and i was like "Bearings are expensove" then i asked my brother the ID of his skate wheels. he said 1/4" so then i got an old one and took a gander TADA!! it fits
32- 1/4" ID Bearings (used) ...... FREE!
the spacer just needs to be cut in half
Unread 14-12-2003, 14:04
Sachiel7's Avatar
AKA: Shayne Helms
Sweet!
Glad you found that one out Tytus, I've been using the globes more frequently in my designs lately.
That helps alot!
-=Sachiel7=-
Unread 15-12-2003, 14:11
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
That is very clever. To expand upon the idea why not try and buy just the bearings themselves. I do not know about the size though. Maybe some skater can help us.
skate bearings
Unread 16-12-2003, 18:38
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
To expand upon the idea why not try and buy just the bearings themselves. skate bearings
I think the idea was that BUYING would cost money..
Matt
Unread 16-12-2003, 20:49
Bill Gold Bill Gold is offline
Retired -- 2006
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
Last year Team #258 used roller blade bearings on shafts in their crab modules. I found them really cheap at a local sports store. The only problem was that none of the roller blade bearings I know of have shoulders or flanges. So we had to glue the bearings into the plates, and try design our plates to better prevent the bearings from trying to pop out. One popped out a little less than halfway through Cal Games, but luckily we had made stainless steel plates (which we hadn’t used until that point) to prevent against this. So we popped a new bearing in, and put the cover plate over it, and it was good to go for the rest of the competition.
Unread 16-12-2003, 21:07
Adam Y.'s Avatar
Adam Y.
no team (?????)
It certainly is cheaper than buying them from any other place.
Neither did the ones that came in the kit. You could probably fabricate your own flange to push-fit the bearings in.
Unread 16-12-2003, 21:14
Retired -- 2006
There were a few flanged bearings in past years' kits. We used them in 2002 on our drive system. I think fabricating your own flange is a little overkill. There are other easier ways of holding the nonflanged bearing into a plate.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
