Go to Post We are just here to give back to a program that gave us so much as students. - Alex Cormier [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 17-12-2003, 07:43
Buster Buster is offline
Buster from 108
#0108 (SigmaC@TS)
Team Role: Scout
Buster is an unknown quantity at this point
Send a message via ICQ to Buster Send a message via AIM to Buster Send a message via Yahoo to Buster
Question Autonomous modes?
Looking for an autonomous code to use as a test. please reply ASAP
TEAM 108 ALWAYS GREAT! www.soap108.com
I came, I saw, I rearranged your BOT!
DRIVE YO ROBOT LIKE THE COPS ARE CHASING YA
Unread 17-12-2003, 09:03
Re: Autonomous modes?
IF auton=0 then 100 'jump if not auton mode
Ldrive = 254
Rdrive = 0 'pre-emptive victory spin
100: 'continue with rest of code
ok, Im joking around - most peoples auton code from last year is specific to there robot - what do you want your bot to do in auton mode?
Unread 17-12-2003, 10:17
* FUNCTION NAME: Sample_Auto_1
* PURPOSE: Primitive form of autonomous mode program
* This overrides the PWM joystick inputs
* CALLED FROM: user_routines.c, Default_Routine
* ARGUMENTS: none
* RETURNS: void
void Sample_Auto_1(void)
static unsigned int counter=0;
/* Sample primitive autonomous mode
* This uses a counter of the number of slow loops as a measurement for how long
* to execute any of the PWM overrides below.
* Note: A timer can also be used in place of "counter"
if (counter<100){
counter++;
PWM_in1 = 200;
PWM_in2 = 200;
else if(counter< 150){
counter++;
PWM_in1 = 127;
PWM_in2 = 10;
else if(counter< 500){
counter++;
PWM_in1 = 127;
PWM_in2 = 127;
else if(counter<700){
counter++;
PWM_in1=254;
PWM_in2=1;
else if(counter<900){
counter++;
PWM_in1=1;
PWM_in2=127;
else /* Make sure it always stops at the end */
PWM_in1 = 127;
PWM_in2 = 127;
} /* End Sample_Auto_1 */
Unread 09-01-2004, 14:13
Buster from 108
#0108 (SigmaC@TS)
Team Role: Scout
thanx man
Unread 17-03-2004, 15:56
CHS_Tommy's Avatar
CHS_Tommy CHS_Tommy is offline
#1368 (Perpetual motion)
Team Role: Driver
CHS_Tommy is on a distinguished road
Send a message via AIM to CHS_Tommy
if you want some more interesting code, our edu bot does the hokey-pokey in the autonomous mode... if you want the code, i can get it from our programmer
put your right foot in, pull your right foot out, put your right foot in and shake it all about....
Raoul got 6 years for murder. He also got $10,000 for the hit. if his common-law wife spends $100 per month, how much money will he have when he gets out?
Extra credit: how much more time will he get for killing the ho that spent his money?
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
crazy idea for autonomous Mike Ciance Programming 16 24-04-2003 21:50
autonomous location manodrum Programming 4 02-04-2003 08:05
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
