Re: Autonomous modes?
* FUNCTION NAME: Sample_Auto_1 * PURPOSE: Primitive form of autonomous mode program * This overrides the PWM joystick inputs * CALLED FROM: user_routines.c, Default_Routine * ARGUMENTS: none * RETURNS: void ************************************************** *******/ void Sample_Auto_1(void) { static unsigned int counter=0; /* Sample primitive autonomous mode * This uses a counter of the number of slow loops as a measurement for how long * to execute any of the PWM overrides below. * Note: A timer can also be used in place of "counter" */ if (counter<100){ counter++; PWM_in1 = 200; PWM_in2 = 200; } else if(counter< 150){ counter++; PWM_in1 = 127; PWM_in2 = 10; } else if(counter< 500){ counter++; PWM_in1 = 127; PWM_in2 = 127; } else if(counter<700){ counter++; PWM_in1=254; PWM_in2=1; } else if(counter<900){ counter++; PWM_in1=1; PWM_in2=127; } else /* Make sure it always stops at the end */ { PWM_in1 = 127; PWM_in2 = 127; } } /* End Sample_Auto_1 */ |
thanx man
if you want some more interesting code, our edu bot does the hokey-pokey in the autonomous mode... if you want the code, i can get it from our programmer
put your right foot in, pull your right foot out, put your right foot in and shake it all about.... ![]() |
| A better autonomous method.. | randomperson | Programming | 4 | 24-02-2004 18:02 |
| crazy idea for autonomous | Mike Ciance | Programming | 16 | 24-04-2003 21:50 |
| autonomous location | manodrum | Programming | 4 | 02-04-2003 08:05 |
| autonomous mode problem on field | Chris_C | Programming | 17 | 26-03-2003 19:11 |
| Autonomous Kill Switch | UCGL_Guy | Programming | 8 | 15-01-2003 17:39 |
