Go to Post The future is a dark and mysterious place, and trying to force our current methods on that are patently absurd. - Taylor [more]
Unread 16-12-2003, 19:27
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Engaging Gears Perpendicular to Shaft Direction?
Many teams, most with reasonable success, have made shifting transmissions by engaging gearsets by sliding gears along an axle with the proper distance between the gears for the correct mesh. This is shown as a top view on my fast sketch below.
What I'm wondering is if there have been any teams that have attempted, with or without success, to engage gear sets in a direction perpendicular to that, as shown as a side view in the sketch below.
1. I am aware this is more difficult
2. I am aware that you need to be careful about backlash and proper spacing
3. I am aware that you run the risk of stripping teeth due to the possibillity of teeth prematuring engaging on the outter-most edges instead of at the pitch diameter.
All that aside, has it been done?
Thanks in advance.
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 16-12-2003, 22:17
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Re: Engaging Gears Perpendicular to Shaft Direction?
Team 469, last years 2nd national champion had a shifter that worked like what you are describing. I got to drive it around at IRI and from what I experianced it worked out very well for them. You could ask them about it because it probably required a lot of work and math.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 16-12-2003, 22:22
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I dont see why this would be any more beneficial than the "traditional" method. You would have to have your shaft and bearing in some sort of slot so that the gear could be engaged. It seems quite a bit more complex for no obvious benefit. Maybe there is one that I just dont see, but as cool as this seems, It doesnt really look too practical to me.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 16-12-2003, 22:45
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
Cory
Well, it all depends on application.
I agree a sloted shaft and gear wouldn't be pretty difficult and wouldn't save any complexity. That's why I've got a gear moving on a pivot. Just looking for feedback on this. Thanks!
Matt
Unread 16-12-2003, 23:28
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
i'm sure that some where in the CD gallery (2001, i thought), there is a picture of a robot that uses a 'swing' shifter that works like the one you described. I would that this sort of shifter might be better than a 'sliding' shifter, because the distance that the shifting mechanism would have to move a very short distance to engage the gear's teeth. of course, this could also work against you, for example if you are a little off on your calculations, you might end up engaging the gears for both high and low speed at the same time.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 17-12-2003, 09:22
one drawback for this idea: when you have gears engaging you want the distance between the centers to be fairly precise and consistant
the gears tend to want to push each other apart
when you have a traditional gearbox, the shafts are held in a plate on bearings - they aint going anywhere
but with your idea, the mechanism that moves into place will have to be precise, repeatable, and in effect it will need to lock-in, so the gears dont push apart under heavy load.
There is a common debug problem with FIRST robots - we often get our bots working great on the table, with the wheels spinning in the air
then when we put in on the floor, and try to push something heavy, gears strip, shafts snap, motors cook.... Its hard to anticipate the secondary forces and effects that take place under a heavy load
other than that, I think if you only shift at a standstill, or when the motors are not loaded up, it should work.
Unread 17-12-2003, 10:01
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
Question Re: Engaging Gears Perpendicular to Shaft Direction?
Originally Posted by KenWittlief
one drawback for this idea: when you have gears engaging you want the distance between the centers to be fairly precise and consistant the gears tend to want to push each other apart.
This is where I'm going to need a mechanical engineer with a little more experience than me...
1. With how much force will they want to push each other apart? I assume that this actually varies... so I guess I'm looking for the maximum force. I assume this is some ratio of the torque.
and the other obvious question is:
2. In which direction is this force applied? As for direction, I assume a significant amount of the force is pushing them directly tangent to where the teeth mesh, but I think this is this too much of a simplification. Is the direction actually related to the gears' pressure angle? What about with mutiple teeth engaging? This seems like it could develop into a rather complex problem...
I'll guess it's something like (T / (D/2))*SIN(PA) is the force pushing them apart in the plane of the shaft centers... but I'd really appreciate it if someone had something better than a guess.
Thanks in advance,
Matt
Unread 17-12-2003, 13:50
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
To my knowledge, many teams (including #469, #60, and #67) have used this type shifting mechanism with great success.
If my memory is correct, teams #469 and #60 both used very wide gears that they slid an idler gear and its shaft axially in order to engage high and low gears.
In 2001, Team #67 used a hex drive shaft and slid the gears on this hex with a motorcycle gearbox style shifting fork.
Anyway, I don't see why folks would argue that this method would be more complex than using so "shifting dogs" to engage gears.
It can be made to work either way.
For those who don't remember, this is the machine that I first recall seeing this type shifter used on (Team 60's 2001 robot):
Joe J.
Unread 17-12-2003, 16:47
Umm Errr...
I have often wondered this, although never mentioned it for the reasons you listed above. I have a toy, which uses some demented form of miter gears in a shifting transmission( i think they call them crown gears. Legos have them too.) Anyway it looks like this:
Please excuse the paint art. This design is probaby impractical for a number of reasons, but none the less i think its interesting. It inspired this:
Its probably still impractical but whatever.
1139 Alumni
Unread 18-12-2003, 00:25
Cory's Avatar
AKA: Cory McBride
Errr, I feel really stupid now. I looked at the drawings and for some reson assumed that you would be pushing the teeth of the gears together, face to face, rather than the diamter, if that makes any sense. This is basically the same system as Team 116 used too.
Cory
2001-2004: Team 100
Unread 18-12-2003, 01:03
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
Exclamation Re: Engaging Gears Perpendicular to Shaft Direction?
Actually.. I think this is what I want to do?
A repost of that picture with some text.
I know you can slide the gear along a shaft into a position.
I want to move the gear and its shaft in the plane of gear rotation, as shown in the bottom sketch.
Feel free to make comments, apparently I wasn't too clear the first time around..
Matt
Unread 18-12-2003, 09:33
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Thanks in advance,
Matt
Matt,
The force between the gears acts along the line of pressure. This line is determined by the pressure angle.
Therefore, you are correct with your formula.
-Chris
Unread 18-12-2003, 10:07
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Matt,
Depending upon the specific circumstances when shifting, and if you are planning to be able to shift "on the fly" then I believe you will have a couple of significant concerns with this type of design. <disclaimer>I am NOT a gearbox expert - engineers with more gearbox/transmission experience are welcomed/encouraged to coment/correct my statements</disclaimer>
1. Stripping the gear teeth could be a huge problem. When the gears first begin to engage (while moving) there will be a significant load concentrated across a very small shear area as just the edges of the teeth of both gears are in contact. At this instant there is also a much larger than usual (about 2X) moment arm which will cause increased bending stresses at the root of the tooth.
2. It will be very difficult to maximize your efficiency while allowing gear shifting in the plane you suggest. A few thousandths of an inch change in center distance can make the difference between gears binding if too tight, or having too much slop/backlash if too far apart.
OK experts ... fire away and educate me ...
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 18-12-2003, 15:28
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
Yes, you could do this, it would take time and in my opinion pretty spiffy enginering. But there would be some issues like grinding. My team had the CIM motors geared down on a the bot we used 2 years agot. Even though the gears were in constant contact, there was a very small bit of play in the distance between two of the gears, this caused the gear to become flat over time. So you would have a big issue with grinding gears in this idea. There is the possibility of binding, too much pressure pulling that gear into the powered gear could cause problems. You also must think about the movement you are creating. You could close out that entire gearbox, so that nothing could get into it, but you probably won't. Having this movement in competition could be a serious problem. If your opponent has an arm or some object protruding out of the bot, that extremety could get between the gears, and you could not shift. You are also creating a nightmare in the repair department. This design, in my opinion, could cause you to spend more money than needed, and cause you to have to repair parts more often.
A tip I use when working on practicle gear box designs is "when designing, draw something would find easy to build and repair, draw something that will accomplish your goal quickly, draw something that will that doesn't have more parts than needed, and draw something that will acomplish your goal in a simple method."
ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
Unread 18-12-2003, 17:19
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
Arrow Re: Engaging Gears Perpendicular to Shaft Direction?
Originally Posted by Mr. Ivey
  • Yes, you could do this, it would take time and in my opinion pretty spiffy enginering.
  • But there would be some issues like grinding.
  • There is the possibility of binding, too much pressure pulling that gear into the powered gear could cause problems. You also must think about the movement you are creating.
  • You could close out that entire gearbox, so that nothing could get into it, but you probably won't.
  • Having this movement in competition could be a serious problem. If your opponent has an arm or some object protruding out of the bot, that extremety could get between the gears, and you could not shift. You are also creating a nightmare in the repair department.
  • This design, in my opinion, could cause you to spend more money than needed, and cause you to have to repair parts more often.
I summerized some of you concerns in bullets. I am aware of all of those, I think I made a pretty clear in my first post:
My response is going to sound grouchy, and I'm definitely not:
Before you start stating problems with a "design", make sure you're actually looking at a design!
(All of those bulleted concerns, especially the last three extrapolations, were based on a 5 second MS Paint sketch with 4 circles and an arrow. It might have been jumping the gun a bit...)
However, I do appreciate the concern, Mr. Ivey. I know your intentions were in the right place. I've just seen this happen in other posts too, by many other people. It's just something I wanted to make everyone aware of to make the CD forums an even better place!
To stick on topic...
Has sliding gears in their plane of rotation in a gear box been successfully done?
Matt
Hint #1 for Ken Leung Shawn60 General Forum 35 11-02-2003 08:04
Need Help on Shaft Mounting... archiver 2001 3 23-06-2002 23:29
