Go to Post "We'll fix that in programming" - EStokely [more]
Unread 23-01-2002, 12:25
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Iventor to 3DS MAX
I have a solution for the inventor / max import
Inventor has a plugin for 3DS max that allows Inventor files to be imported directly into Max.
Inventor and Max must be on the same computer.
Start Max
Under the Customize Menu choose Plugins Path
Choose the Additonal Plugin Tab
Add a new path
...\Inventor\bin
my system is c:\program files\autodesk\inventor\bin
Click use path ( It can be named inventor )
Close Max and restart.
Under the File Import, Inventor files are now available, both part files and assembly files.
It imports the files as an editable mesh
Assemblies import into max in one scene as seperate objects in named Filename01 Filenaem02 etc.....
I have not had any problems with this procedure
Good Luck
Dennis Heberlein
Delphi ELITE
Team #48
Unread 23-01-2002, 12:39
Zeinin Zeinin is offline
#0449 (Blair Robot Project)
Zeinin is an unknown quantity at this point
Send a message via AIM to Zeinin Send a message via Yahoo to Zeinin
thats hella sweet!! i would have guessed that there would be somthing like that going on, seeing as inventor has a liberal amount of MAX code in it, IE its render engine.
1.4 gzh athlon TBIRD
512mbs ddr
GeForce 3
SBLIVE 5.1
Unread 21-01-2003, 20:04
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
Thanks!
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 25-01-2003, 12:04
Pylos Pylos is offline
#0093 (N.E.W. Apple Corps)
Pylos is an unknown quantity at this point
Send a message via AIM to Pylos
i cant get it to work i keep geting an error i dont uderstand it ether but it says sompthing about the paths of the files but they are right
go team 93!!!!
Unread 25-01-2003, 12:46
AJ Quick's Avatar
I am having problems importing huge assemblies into 3DS Max, it appears that it doesn't want to import assemblies with things that use the pattern feature of Inventor.
Unread 16-12-2003, 08:08
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Re: Iventor to 3DS MAX
Last year when I did this, I had a problem importing large files from Inventor in Max. The entire file wouldn't completely transfer through, only bits and pieces. Did anyone else have this problem, and if so how do you fix it??
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 17-12-2003, 02:17
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
I just tried exporting to IGES.
It worked fine with me.
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 17-12-2003, 06:55
But when you export to max in IGES, doesn't it all become one piece and therefore, say I wanted to import our robot from Inventor to Max, well... animating would not be possible this way because Max thinks it's all one piece.
Unread 18-12-2003, 16:10
gsensel gsensel is offline
AKA: Geoff Sensel
gsensel will become famous soon enough
Send a message via AIM to gsensel Send a message via Yahoo to gsensel
This takes work but after importing in to max you could explode it, but then you have to go through and re group all peices that should be one.
Geoff Sensel
Andy Baker used me as a positve example at nationals in 2004!!!!!(Now who is the role model DJ????)
I was looking to start a team for my college for next year, but they got hooked up with a local JR High school doing BEST Robotics competition. Has anyone heard of this?
I was previously on the Technokats from 1998- 2002.
Unread 18-12-2003, 23:06
That would be a lot of work...
How do most teams make their robots anyways??? Do they just create them in Max from scratch or what?
Unread 19-12-2003, 00:13
AKA: Geoff Sensel
I knoew when I was on the Technokats animation team we imported the parts from Auto CAD and then assembled them in 3DS Max
Geoff Sensel
Unread 13-01-2004, 16:18
LBK Rules's Avatar
1467 '06 Alumni
no team (HSRO)
For some reason the plug-in isn't working with max 6.
In fact, none of the plugins that I download for max work.
I am in need of some help...
Anthony Rinaldi
Team 1132: 2003
Unread 13-01-2004, 18:43
Re: Inventor to 3DS MAX
I'm also having the same problem, can't even get the plugin to show up on Max 6... so therefore the option to import inventor files into Max 6 isn't an option. Looks like I'll be importing into 5 and then saving it as a 3DS file, then opening it in Max 6...
Bitmaps as texture in 3ds max? BC1022 3D Animation and Competition 3 28-01-2003 18:32
3ds max VS Maya VS XSI DisTurbed 3D Animation and Competition 7 08-08-2002 22:52
Another 3ds max "Key" Jack 3D Animation and Competition 7 09-05-2002 21:19
Text effects in 3DS Max... Ranma 3D Animation and Competition 6 28-02-2002 21:56
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
