Go to Post We are all insane aren't we? I just want to build a robot now. :P - Lowfategg [more]
Unread 24-11-2003, 09:31
Josh Siegel's Avatar
Josh Siegel Josh Siegel is offline
lurker
#0448 (Crandroids)
Josh Siegel will become famous soon enough
Send a message via AIM to Josh Siegel Send a message via MSN to Josh Siegel
Battery voltage
How would I go about reading battery voltage in PBasic (and C)? In all the examples I've looked at, it switches between batt_volt and bat_volt for the variable.
I'm currently using batt_volt in my code, with it in serin (but not out), and it's never reading anything but 127.
Thanks in advance for any help
Unread 19-12-2003, 10:03
lurker
#0448 (Crandroids)
Re: Battery voltage
Does anyone know how? If so, please respond (it's getting fairly urgent).
Unread 19-12-2003, 10:53
Re: Battery voltage
In PBasic use:
bat_volt VAR byte
'RC Analog Input 8, hardwired to the Battery
'Vin = ((4.7/14.7)* Battery voltage)-0.4
'Binary Battery Voltage = (Vin/5.0 V)*255
c_batt_volt CON 1
Serin COMA\COMB, INBAUD, [oi_swA,oi_swB,rc_swA,rc_swB,p2_x,p1_x,p4_x,p3_x,PB _mode,packet_num,sensor1,sensor2,p2_y,p1_y,sensor3 ,sensor4,p4_y,p3_y,sensor5,sensor6,p2_wheel,p1_whe el,sensor7,bat_volt,p4_wheel,p3_wheel,p2_aux,p1_aux,p4_aux,p3_aux,del ta_t,res01]
bat_volt will be the variable holding the value you want
For the new controller in C it’s:
current_voltage = battery_voltage * 0.038 + 0.05;
To avoid floating point processing use something like
volts1000s = (battery_voltage * 38 + 50);
The value battery_voltage is provided by the Master uP through rxdata.rc_analog01
Unread 19-12-2003, 17:10
lurker
#0448 (Crandroids)
Re: Battery voltage
Thanks for the reply, but I have one question:
That looks like it will hold a variable, but will it read from the edu board? thanks so much
Unread 22-12-2003, 08:28
Re: Battery voltage
I don't have last year's EDU controller handy to verify the PBasic code. It's now locked in the school for the holiday break. We used this code with the 2003 Full RC. The Serin is the Read that loads the variable. You shouldn't be getting 127 in any case. That's neutral on a joystick or wheel input not a voltage. Based on the symptom I would guess that your Serin variable order isn't correct (i.e., bat_volt is falling on one of your wheel inputs. It should be where the EDU default code had sensor8) or the serin flags don't match the serin list of variables. e.g.,
c_p1_y CON 1
c_p1_x CON 1
c_p1_wheel CON 1
c_batt_volt CON 1
Serin COMA\COMB, INBAUD, [p1_x, p1_y, p1_wheel, bat_volt]
Unread 22-12-2003, 10:15
lurker
#0448 (Crandroids)
Re: Battery voltage
Thank you SO much! It was the serin staring me in the face the whole time! I guess thats what I get for sleeping instead of programming... As soon as we get back from break, I'll test it out again. Thank you again!
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
Output voltage in PBASIC diego25 Programming 7 31-01-2002 22:50
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
