Go to Post Silly, Silly, don't you realize there are no borders in FIRST:) - HW [more]
Unread 19-12-2003, 22:32
IrisLab's Avatar
IrisLab IrisLab is offline
AKA: Dave Page
#1466 (Webb School)
IrisLab will become famous soon enough
Re: How Do Planet Gears Work?
Originally Posted by JVN
It was called the CCT - "Crazy Chicken Transmission", designed by Paul Copioli, from Team 217 - The Thunderchickens.
John
This design is interesting. How well did it preform? It's very very similar to the Toyota Prius ECVT as near as I can tell. I'm not an expert in drives---not even close. I recently read an article about the Prius and how it uses a plantary gear system with an additional motor to achieve a CVT.
I noticed that the documents you listed noted that a Patent application was pending. I'd take a look at the Prius system. Maybe Toyota owes the Thunder Chickes team some big dollars! That could finance a healthy FIRST team!
The major difference that I see (and again I'm not an expert) is that Toyota uses a generator in the same way the CCT uses an extra DC motor to control drive speed and distribute torque. In the CCT the extra motor seems to have significant loss (in terms of efficiency) through the second motor. In the Prius, the generator attempts ot recover this power and feeds it back into the batteries.
Also, another diffence is that Prius uses an internal combustion engine as the main drive motor. Can we have a V-8 on a FIRST robot? :-)
Anyway, thanks for all the input. AND THE CCT IS WAY COOL! Thanks!
Unread 11-01-2004, 00:00
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
we are building a continously varible torque, velocity, steering transmission (cvt vst )
but dont ask me how it works...im just the cad dude
btw gears=not fun to model therefore use circles
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
How do i make gears in inventor? mnkysp6353 Inventor 1 16-01-2002 02:31
