Go to Post What should the lesson of FIRST be? Work within your resources to build the most effective machine that you can--and, at the same time, work to increase those resources. - Billfred [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 20-12-2003, 03:01
misterikkit's Avatar
misterikkit misterikkit is offline
will code for food
AKA: Jon B
#0258 (Sea Dawgs)
misterikkit will become famous soon enoughmisterikkit will become famous soon enough
Send a message via AIM to misterikkit
Question Optical Encoders
Does anyone know how to go about using the optical encoders (as in a mouse) w/interrupts in our new controllers?
I have two for each axis coming out of the mouse I got at the WRRF programming seminar, and I'd like to use them.
Thanks!
-j
Unread 20-12-2003, 11:55
IrisLab's Avatar
IrisLab IrisLab is offline
AKA: Dave Page
#1466 (Webb School)
IrisLab will become famous soon enough
Question Re: Optical Encoders
Along these lines...
a) What encoders from Digikey have teams had success with? What part numbers? Are these up for the rigors of competition?
b) Where do most teams mount encoders on the wheel shafts? on a special gear for encoding?
c) How counts per revolutoin (CPR) do most teams use? What design strategy do most teams use when seleteting CPR and encoders in general?
d) Custom circuits? Or us RC PIC interrupts directly? What the trade-offs?
Just curiuos.
Unread 20-12-2003, 14:26
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Thanks!
You promted me to create some example code that should work with your mouse encoders. Details can be found in this thread. Enjoy.
-Kevin
Kevin Watson
http://kevin.org
Unread 22-12-2003, 03:41
The Lucas's Avatar
CaMOElot, it is a silly place
Kevin, Great work on the interupt coding. You saved be a good deal of time looking for the names of the bits I needed to set. I think I noticed an error where the bits for timers 3 and 4 were polled in user_routines_fast.c:
else if (PIR1bits.TMR1IF) // timer 3 interrupt?
PIR2bits.TMR3IF = 0; // clear the timer 3 interrupt flag [93]
Timer_3_Int_Handler(); // call the timer 3 interrupt handler (in interrupts.c)
else if (PIR1bits.TMR2IF) // timer 4 interrupt?
PIR3bits.TMR4IF = 0; // clear the timer 4 interrupt flag [94]
Timer_4_Int_Handler(); // call the timer 4 interrupt handler (in interrupts.c)
Should it be "else if (PIR2bits.TMR3IF)" and "else if (PIR3bits.TMR4IF)"? I do things like that all the time after copying chunks of code. Thanks again.
Robot Inspector
Unread 22-12-2003, 11:08
will code for food
AKA: Jon B
#0258 (Sea Dawgs)
So wait, I don't quite understand how to use interrupts. Are those macros you're using to refer to interrupt pins? Do I have to write code that invokes the handler?
-j
Unread 22-12-2003, 13:28
FRC #2429
Originally Posted by The Lucas
I think I noticed an error where the bits for timers 3 and 4 were polled in user_routines_fast.c...
Brian,
Ugh, you're right and it does look like I just copied the lines above and forgot to change the if() statements. Thanks for catching that. I've updated the code on the website.
-Kevin
Kevin Watson
http://kevin.org
Unread 22-12-2003, 14:04
FRC #2429
No, I'm manipulating the memory-mapped bits directly. The bits are defined in ifi_picdefs.h.
No, that's one of the cool things about interrupts: The hardware executes your code in the interrupt handler automatically when some event happens (e.g., a timer rolls-over or an interrupt pin changes from a 0 to a 1).
What you do need to do is configure the interrupt hardware so it knows how to behave (e.g., interrupt on the rising-edge or falling-edge of the signal on the interrupt pin). Have a look at the interrupt initialization routines for a description of the various ways to configure an interrupt. Also have a look at user_routines_fast.c because this is where the interrupt handlers are mapped to the different types of interrupts.
My goal is to get folks using interrupts, so if you have additional questions, ask away.
-Kevin
Kevin Watson
http://kevin.org
Unread 22-12-2003, 23:13
will code for food
AKA: Jon B
#0258 (Sea Dawgs)
Okay, I'll post questions as I come across them.
To start, how are all those structs in picdefs 'memory mapped'?
-j
Who used wheel encoders CyberWolf_22 Technical Discussion 12 04-05-2003 15:37
optical sensors majormusic2005 Electrical 5 11-03-2003 21:32
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
optical sensors great_one411 General Forum 1 15-02-2003 19:54
range of optical sensors Allie Technical Discussion 1 29-01-2002 09:09
