Go to Post Your wheels look delicious. - Alexa Stott [more]
Unread 21-12-2003, 17:34
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: Worn Shifting Dogs
the technokat white paper is http://www.technokats.org/documents/shiftonfly.pdf
for the 2003 two motor design
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 21-12-2003, 19:31
Matt Reiland's Avatar
'The' drive behind the drive
Exclamation Re: Worn Shifting Dogs
Last year we were using the Generation 1 Technocats shifter that had the separate dogs mates attached to the gears. In practice we had assembled the transmission too narrow and while at full speed it shifter and ended up in high and low immediately locking up the transmission and shearing off the three screws that held the dog mate onto the gear. We took it apart and welded the gear to the dog mate and it worked for a while longer until it was assembled yet again narrow. This time, under a full power shift it again locked up the transmission but the shock went through it and sheared off the motor pinion on the bosch. We put a new motor in and used it the entire season and post season with no signs of wear on the dog or dog mates. With generation 2 having the dog mate milled into the steel gear it looks to be even stronger. My 'non- expert' opinion is that it is oversized for the loads that are being applied to it by our motors in the kit and for its limited use in a FIRST season it works spectacularly.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Shifting Gears MBosompra Technical Discussion 71 23-07-2004 02:49
gear shifting Stephen Kowski Motors 19 30-03-2003 21:33
Junkyard Dogs NeO_Weapon General Forum 6 13-04-2002 22:59
Shifting Gears -- Anton Abaya Technical Discussion 26 22-01-2002 21:49
Visteon to leave teams to the dogs? nwagers Rumor Mill 6 24-10-2001 10:56
