Go to Post Seriously, I figured we had until january before we started lawyering things again. - JamesBrown [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 21-12-2003, 17:31
Vienny Nguyen's Avatar
Vienny Nguyen Vienny Nguyen is offline
Go Bucks!
FRC #1326 (Cy-Ridge Robotics, alumni/contact; Team 382, coach)
Vienny Nguyen is on a distinguished road
Send a message via AIM to Vienny Nguyen Send a message via Yahoo to Vienny Nguyen
DB9 Adapter
Hey,
I just purchased a laptop so that my team could work on programming at competition, but I can't connect it to the edu rc. I only have a printer port, monitor port, and two USB ports. I just wanted to know if I would be able to load programs from the laptop to the controller if I purchased like a DB9-DB25/DB15 or USB adapter. I'm just confused because the IFI loader only shows com ports under port settings.
We're a rookie team so I don't really know how to use this stuff...
Thanks for your time,
~Vienny
What would you do if you knew you couldn't fail?
Unread 21-12-2003, 17:43
Re: DB9 Adapter
you would need something more than just a connector adapter (DB9 to USB connector) because the signals themselves are different
what you need is a USB to serial port converter (adapter?) that will translate the USB commands to RS232 commands.
Ive heard other people mention these on the forum. I assume the SW that comes with it will make the USB adapter look like a com port on your laptop, so the IFI program can find it.
Unread 21-12-2003, 17:46
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Re: DB9 Adapter
http://www.chiefdelphi.com/forums/sh...ad.php?t=22424
Apparently, you can use Serial->USB converters just fine. I have no personal experience with it, but others on the forum have.
Unread 21-12-2003, 21:23
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Re: DB9 Adapter
Just a comment on USB-to-serial adapters. I bought one from Belkin that was designed for use with PDAs, and it didn't work. I later bought a Keyspan mini port replicator, which had Serial, Parallel, and extra USB ports on it, and that worked fine for me. I really have no idea why, but that was my personal experience.
Jeff Waegelin
Unread 21-12-2003, 22:04
Go Bucks!
Re: DB9 Adapter
Thanks for your replies, guys... it is much appreciated.
~Vienny
Unread 21-12-2003, 22:12
ErichKeane ErichKeane is offline
FRC #3210
ErichKeane is just really niceErichKeane is just really niceErichKeane is just really niceErichKeane is just really niceErichKeane is just really nice
Send a message via AIM to ErichKeane
Re: DB9 Adapter
actually, radio shack has the cable for 40 bucks w/ a driver disk, kinda expensive, but it does map it to a com port.
If you search on froogle, you can get one for as low as 15 bucks or so shipped. A few sites to choose from below:
http://store.yahoo.com/store4pc/usbtoser9pin5.html
http://www.more4mymoney.com/catalog/...oducts_id/4169
http://www.spacecentersystems.com/ca...oducts_id/5086
EAch one i belive works fine.
Unread 22-12-2003, 12:07
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Bafo Technologies
I said it before, I will say it again. I had NO success with Belkin stuff. I have had great success with the Bafo-810 They cost about $15 from TigerDirect.com
Joe J.
Unread 22-12-2003, 16:08
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: DB9 Adapter
Yesterday, I ordered this CP Tech adapter from TigerDirect.ca for $24 - oops, that's Canadian. Umm... $17 US. When I get it, I'll let you guys know if it works or not.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
running the OI off a battery AlbertW Electrical 25 29-04-2003 13:09
Window Motor Gear?? BBFIRSTCHICK Motors 6 03-02-2003 14:09
Adapter great_one411 General Forum 2 02-02-2003 12:39
USB to Serial Jack Programming 24 23-12-2002 14:21
A/C adapter for OI Bill Gold Technical Discussion 5 23-10-2001 23:51
