Go to Post Grease, blood and cookies... it must be build season. - danshaffer [more]
Unread 18-12-2003, 19:59
mightywombat's Avatar
mightywombat mightywombat is offline
bins? stacking?? NOOOOO!
AKA: Bill Rosemurgy
#0857 (Superior Roboworks)
mightywombat is on a distinguished road
Question math.h library
I need to use some trig functions in some code that I'm writing for our kiwi drive train. Does anyone know where to find C libraries (specifically the math.h)? I've found the GNU C library but didn't think it would work because it said that it only ran on GNU systems. All I need is simple sin cos and tan funcs.
peace.
bill
Unread 18-12-2003, 22:12
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Re: math.h library
Hi.
I recall that Mike Betts and Dr. Joe had some good comments on trig functions in this thread:
http://www.chiefdelphi.com/forums/sh...highlight=trig
(named "Edurobot and arrays" from November, in this forum)
For just sin, cos and tan, you might want to make a linear table lookup.
I've downloaded the cmath library from www.netlib.org/cephes, but I haven't tried it out on the edu rc
Eric
Don't PANIC!
S. P. A. M.
Unread 18-12-2003, 22:14
AKA: Bill Rosemurgy
Re: math.h library
thanks alot. i'll check it out. although i did find that math.h does in fact come with the compiler after doing a search on my comp.
Unread 19-12-2003, 00:37
AKA: Bill Rosemurgy
Re: math.h library
whats a linear table lookup?
Unread 19-12-2003, 08:18
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Re: math.h library
The only issue with a table lookup is that you're confined to the values you put in your table.
You can use an approximation called the Maclaurin series for Sine, Cosine, and Tangent. The formulas are listed below. The angle, x, is in radians. There are 2*Pi radians in a circle, so 360 degrees = 2*Pi radians. These formulas match the actual Sine, Cosine, and Tangent to three decimal points.
Sine(x) = x - x^3/3! + x^5/5!
Cosine(x) = 1 - x^2/2! + x^4/4!
Tangent(x) = x + 2x^3/3! + 16x^5/5!
This is a special case of the Taylor series, which I'll leave to you look up. The Taylor series would allow you to reduce the number of terms you're calculating by using know values of Sin/Cos/Tan near the angle you're looking for.
The ! is the factorial operator and just means to take the number and multiple it by every number between it and 0.
3! = 3*2*1 = 6
4! = 4*3*2*1 = 24
Unread 19-12-2003, 08:45
Electrical Engineer
Rookie Year: 1995
Re: math.h library
A Taylor Series expansion solution for sine and cosine would look like this (if you are doing floating point arithmetic) with angle in radians:
angle_pow_2 = angle * angle;
sin_angle = -0.0001984127 + (angle_pow_2 * 0.0000027557);
sin_angle = 0.0083333333 + (angle_pow_2 * sin_angle);
sin_angle = -0.1666666667 + (angle_pow_2 * sin_angle);
sin_angle = 1.0 + (angle_pow_2 * sin_angle);
sin_angle = angle * sin_angle;
cos_angle = -0.0013888889 + (angle_pow_2 * 0.0000248016);
cos_angle = 0.0416666667 + (angle_pow_2 * cos_angle);
cos_angle = -0.5000000000 + (angle_pow_2 * cos_angle);
cos_angle = 1.0 + (angle_pow_2 * cos_angle);
Since our team will be using integer arithmetic exclusively on the PIC, we generated a table using Excel (saved as a CSV file) and imported into the PIC code as a table of constants existing in ROM space.
Note that only sine from 0 to 90 degrees is required as the function is symmetrical. Both cosine and tangent can be mathematically generated from the sine.
The problem with math.h is that it returns a double and you really do not want to do floating point on your 'bot. The nice thing about a table lookup is that you control the format of the stored (returned) variable. In our case, an integer in 2FX14 format.
Hope this helps.
Mike Betts
As easy as 355/113...
Unread 19-12-2003, 13:49
AKA: Bill Rosemurgy
Re: math.h library
sweeeeetness. this rocks. i've got a few questions.
do you suggest reading all of the values from 0-90 (in fact you'd only need 0-45 because sin (46-90) = 1 - sin (0-45)) into a matrix or actually calculating them?
I'm also confused as to the difference between ROM and RAM space. I know what the acronyms stand for but thats about it.
why no floating points? is it too much for it to handle? are there any other things i should stay away from calculation/variable wise?
Unread 19-12-2003, 14:01
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: math.h library
For us math geeks, there is also the most wonderful CORDIC algorithm. I suspect that it'll be faster than the Taylor series. I found a pretty good FAQ (with code) here.
Kevin Watson
http://kevin.org
Unread 19-12-2003, 14:04
FRC #2429
Re: math.h library
Division is very painful without hardware support.
-Kevin
Kevin Watson
http://kevin.org
Unread 19-12-2003, 14:22
AKA: Bill Rosemurgy
Re: math.h library
whoa.. that CORDIC is rather confusing stuff. I'm going to play with it and see if i can figure it out a little more.
so you are saying that I should stay away from dividing two numbers?
(the question sounds dumb but i'm very surprised that it would be so tough)
I remember reading that it can handle addition VERY well but doesn't do much else as quick. thanks for the quick reply.
Unread 19-12-2003, 14:33
FRC #2429
Re: math.h library
Yeah, you gotta be a math geek to like the CORDIC .
so you are saying that I should stay away from dividing two numbers? (the question sounds dumb but i'm very surprised that it would be so tough) I remember reading that it can handle addition VERY well but doesn't do much else as quick. thanks for the quick reply.
Well, I shouldn't have made such a generalization. Integer division by powers of two is very fast (if the compiler is designed for such an optimization) because you only need to do a binary right shift to divide a number by two (multiplication works by shifting left). Division of two eighty-bit IEEE floating-point numbers on an eight-bit microcontroller is very painful.
-Kevin
Kevin Watson
http://kevin.org
Unread 19-12-2003, 14:44
FRC #2429
Re: math.h library
-Kevin
I forgot to point out that with timer support, it would be very easy to profile the different algorithms to see which is most efficient on the PIC18F8520. I just happened to have written some example timer code that might help.
-Kevin
Kevin Watson
http://kevin.org
Unread 19-12-2003, 15:22
Electrical Engineer
Rookie Year: 1995
Re: math.h library
Check your math... I think that 0-90 degrees is the minimum you want to try.
RAM is cleared to zero (at best) or random noise after a power up. ROM is non-volatile.
I would suggest you do a search of these fori (I still like that word, Dr. J!) for other discussions on floating point. Bottom line: The PIC18C is not a floating point processor...
Mike Betts
Unread 26-12-2003, 14:41
Joshua Lynn Joshua Lynn is offline
FRC #0423 (SEC Mechanical Mayhem)
Joshua Lynn is on a distinguished road
Re: math.h library
I am currently working on a math library for trig functions and a few other floating point operations like floor, ceiling, and sqrt. I hope to have them available by Jan 10.
These functions are based on other open source numerical methods. The trick is the need to be converted from their double data type operations to float data type in the format used by the PIC which is not IEEE 754.
The solutions are all based on various forms of approximation.
For those who want to try it themselves here is an iterative way to calculate the sqrt:
y=sqrt(x)
y0 = x/2
y1 = (y0 + x/y0)/2
yn = (yn + x/yn-1)/2
Iterate through the solution n times until you have the desired level of precision. For low values of x the convergence is good for n=10. For larger values the first guess should be adjusted to reflect the order of magnitude of x. If x =10^6 start with an initial value 10^3 or (Order of Magnitude)/2. The closer the first division is to the answer the sooner the number will converge.
So far I have worked out
SQRT
SIN
COS
TAN
SEC
CSC
COT
Floor
Ceiling
ABS
I will have at least one of the following trig functions
ATAN
ASIN
ACOS
I may be able to get them all but I have a bit more research to do.
Additionally, I have found other methods to calculate
ln
Log
MOD
x^y --Used for larger values of y it is more efficient
Stay tuned for more.
Unread 03-01-2004, 01:12
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: math.h library
I did a quick Excel spreadsheet to see whether a linear or parabolic interpolation was better (I expected the parabolic to be better).
I used 128 values 16 bit values in my table for a 90 degree section of the sine function (I realize this is a prettty thick mesh, but it is only .25Kbytes for my entire sine and cosine approximation which seems small enough). Anyway, I was only off at most 2 counts of a 16 bit output with a linear interpolation. Surprisingly (to me at least) the parabolic interpolation was worse! It was sometime off by 3 counts and also had a higher average error. I suppose that this could be due to the fact that sine is a x + x^3+ x^5 ... function (note no even powers) while I was adding a x^2 term to my approximation.
Bottom line: a max 2 counts out of a 16 bit number is going to be fine for me and my robot. I plan out writing a simple lookup table with linear interpolation (at least for sine and cosine -- we will see about tangent, arcsine, arccosine and the all important arctangent).
Joe J.
The New and Improved FIRST CAD Library Ed Sparks General Forum 22 03-02-2007 18:03
Pneumatic Valves Posed in First Cad Library Ed Sparks Inventor 0 19-01-2003 17:33
Gear Box Parts Posted on First Cad Library Ed Sparks Inventor 1 10-01-2003 01:54
CAD Library Updated ..... Ed Sparks General Forum 0 21-01-2002 18:19
HELP NEEDED using CAD library ahecht Inventor 9 21-01-2002 11:50
