Go to Post We have seen the difference in people's lives on our team as they went through the program. There are all sorts of examples, and I am sure you (and everybody other team) have similar stories. At the end of the day, that is really all that matters; changing lives in a positive manner. - tim-tim [more]
Unread 27-12-2003, 11:00
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Re: Interrupt limitations?
Originally Posted by randomperson
hmm... this just kind of occured to me..
Ok, yes we can now find exactly when something is happening by being interrupted... but we still cant send out data more than every 17ms (or 25 for the edubot). ill post it nonetheless... any thoughts on this?
Some of the inputs (digital and analog) can be read directly and some of the outputs (definitely digital and I think PWM) can be written directly without going through the communication to the master uP. You'll have to dig through the default code to find which ones allow this.
If you plug through the timer code that IFI put together (http://www.innovationfirst.com/FIRST...ite_papers.htm), you will find out how to output a digital out every n millisec. I've run those mods (with some additional mods of my own, of course) and 'scoped out a 10 msec sample time. It was very reliable (ie no periodic glitches due to overflow or other stuff interrupting the low priority interrupt).
EDU Interrupt and Timer Template Code Kevin Watson Programming 8 22-12-2003 14:11
Operator Board Size Limitations?? archiver 2001 6 24-06-2002 00:37
Gray box limitations Tim Skloss Technical Discussion 1 23-01-2002 07:38
wheel limitations Greg Needel Technical Discussion 1 15-01-2002 16:37
Kit Materials Usage & Limitations Rockstar75 Rules/Strategy 1 10-01-2002 17:19
