Go to Post Stand scouting allows you to get to know the robot. Pit scouting allows you to get to know the team. - Taylor [more]
Unread 28-12-2003, 05:50
rwaliany's Avatar
rwaliany rwaliany is offline
R
None #0691 (HartBurn)
rwaliany will become famous soon enough
Linux with the PIC
I got the PIC with the C18/IFI working on Linux. What you need to do is install wine and install the MPLAB/C18/IFI software with wine. However, MPLAB isn't compatible with wine. Thus, here is a makefile using wine to do all your compiling and linking using the c18 compiler mcc18. I'll get more support later, but this allows you to compile the files in the terminal and use whatever editor you want. Then you can just run wine and send the files. I suggest getting the codeweaver trial office to install it, then just wine to manage it. 3AM gotta sleep have fun.
wget http://xp.scv.net/x2545/code.tar.gz
tar -xzvf code.tar.gz
cd code
make
#after wine is installed with c18 etc, don't forget to edit the Makefile to configure paths
R
Unread 28-12-2003, 09:05
mikew mikew is offline
crazy coder
#0613 (Franklin RoboWarriors)
mikew is an unknown quantity at this point
Send a message via AIM to mikew
Re: Linux with the PIC
The IFI loader works on regular wine now?
Unread 28-12-2003, 20:14
rwaliany's Avatar
R
It works on CodeWeaver (wine) for me...
R
Unread 29-12-2003, 02:08
rwaliany's Avatar
R
It turns out, it copies, but it's corrupted and it won't go pass the Fault Status, but that goes away with same code in Windows. Working on script to do it.
R
Linux SteveC116 3D Animation and Competition 22 25-03-2004 15:07
Linux And Windows XP Raven_Writer Chit-Chat 4 06-08-2003 18:53
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
RoboEmu for Linux (PBASIC emulator) rbayer Programming 5 21-11-2002 21:08
Linux file extensions rbayer CD Forum Support 5 14-11-2002 23:04
