Go to Post Make sure you THOROUGHLY understand the rules of the game before you actually start designing the robot. - Koko Ed [more]
Unread 28-12-2003, 17:43
mzitz2k's Avatar
mzitz2k mzitz2k is offline
Robotics Fiend
AKA: Matt Zitzmann
None #0302 (Mechanical Dragons)
Team Role: Student
mzitz2k will become famous soon enoughmzitz2k will become famous soon enough
Send a message via AIM to mzitz2k
Caster Mechanism
I was wondering if a team has ever created a caster mechanism that raises and lowers one end of a robot. I know this is an easy mechanism to produce, but I would love to actuate it with just one window motor.
With a 4-wheel drive robot, the caster mechanism would have to lift 1/2 of the robot weight (assuming the weight is evenly distributed), which is 65 lbs = 289.5 Newtons. According to the specs the window motor is going to provide approximately 4.6 Nm of torque (this is 1/2 of the stall torque), which means the lever arm (off the motor) must be pretty small - or - one could gear the window motor down to achieve this actuation, but then speed of the caster actuation is lessened.
I would love to have two casters that work off of one mechanism allowing to lift the robot up and down off the ground.
Appreciate any tips!
Unread 28-12-2003, 18:45
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: Caster Mechanism
Yup, one team that used this type of caster mechanism was the Cheesy Poofs, team 254. I have a feeling that they used pneumatics though, not a window motor. They used the caster to alternate from 4 wheel tank drive and 2 wheel car drive. Why do you want to do it with just one window motor? Do you want this mechanism to use 2 casters to lift up the end of the robot? The Cheesy Poofs only used 1 caster. What I am going to assume is that you want to lift 2 wheels off the ground so you can steer differently. In this case, you only need to lift those wheels off the ground by like, a centimeter, so I think pneumatics is the best solution for this problem. To turn a lever with that much force will demand for some pretty thick shafts. You'll probably have to attach a sprocket to the window motor and gear it down a bit, and all this adds up to a lot of useless weight. You could do it with a window motor, but I strongly suggest doing it with pneumatics. All you need is a small cylinder with a thick bore, so it can give the 65 pounds of force. Stick a caster on the end of that, and you're done.
Unread 28-12-2003, 18:46
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
my old team 312 had a castor mechanism that that started out being driven by the window motor, but in the end was pnuematically driven, because it was much simpler
http://www.firstrobotics.net/03galle...0312-1_JPG.htm
you can also see the optical sensors attached to it that we used during auto mode.
i believe that SPAM (180) had a similar device last year, and that Wildstang (111) used a retractable skid plate
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 29-12-2003, 01:58
mzitz2k's Avatar
Robotics Fiend
AKA: Matt Zitzmann
Team Role: Student
Thanks for all of your help and tips. The reason I would really enjoy accomplishing this mechanism with a window motor is so that we don't need to waste all of that weight on a compressor, accumulator, tubing, gauges, etc. that come with using pneumatics.
Matt
Team 302 - "The Mechanical Dragons"
Engineering Inspiration Award - Western Michigan Regional (2004)
Division Champions - Newton Division (2003)
Regional Champions - Great Lakes Regional (2003)
General Motors Industrial Design Award - Great Lakes Regional (2002)
Motorola Quality Award - Buckeye Regional (2002)
Regional Finalists - Buckeye Regional (2002)
Division Finalists - Newton Division (2001)
Regional Finalists - West Michigan Regional (2001)
Unread 29-12-2003, 02:46
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
after getting all the gearing and everything that would be needed to lift the sides of the robot effectively and reliably.. it might be close to the same weight.. if its a few lbs lighter.. you might want to ask yourself is worth the effort?
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 29-12-2003, 09:58
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
As StudManDan pointed out, it will likely be close to the weight of a pneumatics rig being on the bot. However, it can be done with a single cylinder leaving (should rules stay the same) 3 availible for use. Don't rule out pneumatics on weight alone, straight-line actuation can be your friend.
Unread 29-12-2003, 10:36
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Our team the TIGERTRONS just did this our first time in the year 2003
In the past we found it very difficult or impossible to turn our robot in high gear with 4 wheel drive. This past years game we decided we needed to become very maneuverable so we had to change something...
So We created a pair of casters that were directly mouted to our stationary front axle. We then used a Globe Motor that was mounted to our frame. The Globe Motor also had a lead screw directly attached to the shaft.
The Globe then pivoted the castors on the stationary shaft. We also used a pair of limit switches to control the movement of the mechanism so that us drivers would not destroy it.
The only drawback was that is was rather slow. It took like 3-5 seconds to shift from 2 wheel drive to 4 wheel drive. Our front shaft also bent during one competition due to falling from verticle to horizontal on our castors that were down. We later fixed the problem by installing a solid 1/2 inch shaft instead of a hollow 1/2 inch shaft.
For pictures and more information please visit:
http://www.tahsroboticsteam.org/pictures.htm
http://www.tahsroboticsteam.org/robot2003.htm
I can try to get more detailed pictures of the mechanism if you want
just send me a pm or email at rigdonbrad@hotmail.com
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 29-12-2003, 11:41
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Should this mechanism exist at all?
I guess I'd just like to offer a few cents on this, because I have no doubt that this is common problem. There's a few different schools of thought. I'll offer my own. I'm sure others will chime in.
Pneumatics are an excellent but limited resource, often underused and underappreciated. I noticed that last year a number of teams had a "trick wheel" to aid in high-gear steering. I think the only reason that they could "get away with" using a pneumatic for this mechanism is since so few teams actually had any sort of complex manipulators that required penumatics.
Essentially, I think that using a pneumatic in this situation (unable to turn in high speed) isn't the best use of this resource. I'd rather try to properly design my high speed setting such that I could turn without this device. For better or worse, in almost every game that's been played so far, I'd rather just go 9 feet per second (faster than more than 70% of the competition) in high and have a spare pneumatic to use, rather than go 12 or 13 fps and need an addition device, which upon failure means that I have effectively neutralized my transmission. I know it depends on the game... but in principle, I think there's a more sound approach.
Just my pair of pennies...
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 29-12-2003, 13:07
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Last year we wanted a very mobile robot and planned for a 2-wheel drive with casters. I introduced the idea of HDPE "glides" instead of casters for a couple of reasons. The rounded "skids" worked very well as they slid smoothly on the carpet as well as the ramp, and we avoided any resistance due to casters having to orient the correct way and/or fighting each other "directionally". They were also large enough to span over the grid in the ramp wire mesh, therefore eliminating the bouncing we would have seen from using casters. We also needed to raise and lower the back of our robot and used the pneumatic actuation system shown below:
http://us.f1f.yahoofs.com/bc/63e9492...58G8_AwWYPomxv
This arrangement worked great, and using the large pneumatic tires we also had a significant amount of traction.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 29-12-2003, 22:07
JessR JessR is offline
#0571 (Team Paragon)
JessR will become famous soon enough
In 2002 Team Paragon also used a castor option to add 2 wheel steering behavior to our tank tread drive, which of course was a bear to steer & overheated the motors when turning a lot.
We used a seat motor & cords pulling a couple of flaps with castor wheels mounted, one in each corner of the chassis. It worked great, outside the 4 second activation time - As noted above, worm drive motors llike the seat & window motors take about that much time to lift 60 lbs.
Depending on the game dynamics, I would lean to either using a small pneumatic cylinder & pre-charged onboard air tank(s) without the compressor, or a fisher price gearbox or similar driving a cam.
It depends on how often you'd have to drop down on all fours for shoving matches.
Jesse.
Name:	robot feb02-196 Chassis1B.jpg
2004 UTC New England Champions with 716 & 230
Engineering Lead
Team Paragon #571
Unread 01-01-2004, 16:39
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Pneumatic is best for very quick activation
Yes, we used a skid plate to go into two-wheel drive for quick rotations of the robot. We used pneumatics for this for a simple reason - it can be actuated very quickly. The window motors can be geared properly to raise the robot, but the required gearing would make it move very slowly. If we used the window motors, we would have to wait too long to lower the skid and not be able to make very quick movements. Keep in mind that in last year's game, we had to raise our skid plate completely out of the way to allow for clearance while going over the ramp.
Raul
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 01-01-2004, 17:01
In 2002, Team 340 did something similar. They used two wheel drive, with two ball casters on the far edge of the robot. When they grabbed a goal on the side with the wheels, they then actuated two pneumatic cylinders that lifted the casters off the ground and also lifted the opposite end of the goal. Thus, they had half off the goal transfering weight to the drive wheels with nothing dragging. It gave them a great turning radius.
Building a better caster. Madison Technical Discussion 14 16-01-2003 22:53
Wheel Hub Connectors for Skyway Wheels Wayne C. Kit & Additional Hardware 16 10-01-2003 07:16
Weight Distribution Mechanism in Tread System? Kai Zhao Technical Discussion 8 20-08-2002 16:38
Goal feeding ball mechanism????? Rob Kelly Technical Discussion 2 03-02-2002 23:28
"Ball Return" mechanism... what is it? Randy_Ai Rules/Strategy 1 09-01-2002 16:12
