Go to Post FIRST truly isnt about building robots, but allowing yourself to reach higher and farther than you ever could. - Brandon Holley [more]
Unread 31-12-2003, 13:07
[494]Hal9000 [494]Hal9000 is offline
[494]Hal9000 has a little shameless behaviour in the past
Programming with OSX
is there anyway program in the new Pic C language on a Mac running OS 10.3???? Will running VirtualPC be the only way? I just don't want to use the 6yr old piece of junk that has no battery that i have in our robotics lab
Unread 31-12-2003, 14:04
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Re: Programming with OSX
YEAH! Power to the Mac users. I believe that you need a serial port to transfer info, but I havn't gotten a good look at the controller this year, we have had the controller hogged by our programmers....
Unread 31-12-2003, 14:08
Umm Errr...
VPC w/a USB to serial port adapter is the only way to run C18 under OSX.
You can buy one of these adapters from must any place that sells computer stuff.
1139 Alumni
Unread 04-01-2004, 08:51
ok next question, i know you can go ahead and write code in a note pad like program, but would i be able to use "X Code" apples software development software to write the new C language.
And is the Language "C", "C++", or "C#" i'm confused on what sintax it is.
Unread 04-01-2004, 09:02
ok, it's writtin in "C", did a little more stumbling acrossed the interweb and got that cleared up.
I'm stilll not sure if X-code will compile "C". I mean Unix is written in "C", OSX is Unix with a pretty GUI. Anyone know if x-code will compile "C"??????
Unread 04-01-2004, 09:17
Skabana159's Avatar
Skabana159 Skabana159 is offline
Robotics and Field Hockey
AKA: Jesse C. Owens
#0159 (Alpine Robotics)
Skabana159 is on a distinguished road
Send a message via AIM to Skabana159
Code written for the PIC will compile in your OSX box, because unless you do something really tricky, C18 is ANSI-compliant (standard syntax).
However, if you simply use your normal compiler, rather than the C18 compiler, you will not get a usable hex file for the PIC. You must use a compiler meant for use with the PIC because your mac and the PIC have vastly different archetectures. I would go with the VPC, if I were you.
You can still use the X-Code development environment, if you just want a pretty IDE (Integrated Development Environment) to make writing easier. You just can't compile with this either.
I feel some of your pain, being a Linux user myself, and have found that the only way for me to do it is to use a program called Wine (Win emulator) to run MPLab...
"What most people do not understand is that the Buddha, the Godhead, resides just as comfortably in gears and circuits as in hills and trees. To believe otherwise is to dilute the Godhead."
-Robert Pirsig, Zen and the Art of Motorcycle Maintenance
Unread 04-01-2004, 12:21
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
I am not an expert by any means, by I know that x-code only compiles in gcc. This is one of the biggest complaints against x-code, and another reason people still buy the expensive codewarrior.
X-code is specifically designed for just writing programs in Panther. It was never meant to compile programs for embedded processors. Now that doesn't mean that it can't, somebody one day could make an add-on compiler for x-code or any other program.
It really sucks that mac users finally got the ability to be able to program in PBasic, only just to loose that ability by Innovation FIRST switching to a different language and compiler.
However I do understand that PBasic was very limited, and many FIRST teams wanted a more advance language to be able to program more.
Unread 04-01-2004, 12:55
Umm Errr...
Well i'm not sure i understarnd ur question. If you are asking if you can write code in somethign other than C18 anf then use C18 then the answer is absolutely! If you are asking if you can compile code for the pic using somethign other than c18 then the answer is no!
1139 Alumni
Unread 04-01-2004, 17:51
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
Being a Macintosh user, and employed under the name Macintosh, I will throw in a suggestion. Go to Apple's downloading section, and look through the development tools given, they are either freeware or shareware/demo versions of the software that you guys may be able to use for programming your bot this year. I'll give you the link: Apple Development Tools for OS X. I hope this helps. Also about an adaptor for using serial, Keyspan offers one, and I know it has been used in previous years and works pretty well.
Ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
Unread 07-01-2004, 14:31
http://www.apple.com/downloads/macos...vironment.html
GNU Development Environment:
A complete suite of GNU C, C++, Fortran, and Java Cross Compilers, and the GDB CPU Simulator and Debugger for embedded microprocessor applications development. Targets development for ARM7, ARM9, and XScale applications
I don't know if this would help or not, i'm thinking not.
Unread 11-01-2004, 02:42
rwaliany's Avatar
rwaliany rwaliany is offline
R
None #0691 (HartBurn)
rwaliany will become famous soon enough
Hey, It turns out the IFI Linux PICloader I wrote for Linux works with my friends Mac OS X ibook with a few tweaks dealing with termios.h. I'm working on a port, but I don't have a mac. The only problem is figuring out a way to run MC18 on Mac Os X by using an emulator of some sort, any ideas? Anyone want to look into Bochs x86 compiler or wine, if there's support for mac.
Thanks,
Ryan Waliany
R
Programming Compatition Angela06 Programming 30 08-04-2005 23:12
programming the compressor archiver 2001 4 23-06-2002 23:19
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
pbasic programming punarhero Programming 4 21-01-2002 23:32
