Go to Post The teams who have the best chance at success are the ones who know where they can save time and money on machining by using or using part of some premade equivalent. - Bill Gold [more]
Unread 30-12-2003, 10:17
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Picking Out Roller Chain
Can someone tell me what the calculations are for determining the choice for roller chain? I am guessing the terms you use are the maximum working load and average tensile strength but how do you calculate what that is going to be in the robot.
Unread 30-12-2003, 10:58
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: Picking Out Roller Chain
Adam,
In its simplest form you need to calculate the torque at each sprocket and the find the resultant force on the chain. For example if you have a torque at the sprocket of 2000 inch-lbs and have a 4 inch pitch diameter sprocket, the force at the pitch line on the chain is 2000/2 = 1000 lbs. Since we like to have a safety factor of 2-3 than you would select a chain size with a breaking load in the 2000-3000 range minimum. #35 falls into this range. The load needs to be calculated from the direction that is applying the greatest force. For the drive, the wheels generally slip before the maximum torque of the motors is achieved. A lift mechanism may get jammed or try to lift an immovable object, the torque in this case is from the motor side.
Word of caution, sprocket teeth can also break. Try to use a sprocket with as many teeth as possible, the load is shared by each tooth so the more the merrier.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 30-12-2003, 16:58
Adam Y.'s Avatar
Adam Y.
no team (?????)
What is the differnce between double pitch and single pitch roller chain?
Unread 30-12-2003, 17:05
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Double pitch roller chain has a pitch twice as large as single pitch equivlant chain. A double pitch chain should have the same strength as it's ansi equivlant, but weigh less because there are fewer rollers (note that a chain's pitch is the distance between rivets).
Thats the best I can do without a picture, you might try searching chain pitch on google.
Greg
(edit: for readability)
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 30-12-2003, 17:20
Adam Y.'s Avatar
Adam Y.
no team (?????)
According to Mcmaster:
Working load is the maximum load capacity that can be applied to the chain under normal operating conditions. Average tensile strength is the average load capacity at which the chain will break
Never mind I just answered my own question. Now what will happen if you constantly run the chain over the work load but under the break load?
Thanks for the help.
Unread 30-12-2003, 17:59
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Picking Out Roller Chain
Essentially, it's longevity will decrease, and it will eventually break. Chain (like any component) has a finite service life. Often times, chain isn't designed with sudden stops and changes in direction in mind. On the last leg of your drive train when you're connecting sprockets to wheels, just play it safe and go with #35.
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 30-12-2003, 18:20
Adam Y.'s Avatar
Adam Y.
no team (?????)
Matt
All right that is not a problem. Since the chain I am looking for only is sold at #40 and above. Though I wonder if using it as a tank tread will change anything. It is called ANSI attachment chain.http://www.mcmaster.com/
Unread 30-12-2003, 19:50
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
...the chain I am looking for only is sold at #40 and above. Though I wonder if using it as a tank tread will change anything. It is called ANSI attachment chain.http://www.mcmaster.com/
I guess I'd like to see what you're going to do with it... those links are so darn expensive! In addition, #40 chain is one heavy hunk of metal. However, I'm curious to see what you've got in mind.
Matt
Unread 30-12-2003, 21:08
Adam Y.'s Avatar
Adam Y.
no team (?????)
I read a book that suggested using the attachment/conveyor chain as a tank tread. More specifically I want to use the chain with the flat attachments. I thought that by bolting on neoprene rubber inbetween two chains it would make a nice (abeit expensive and maybee heavy) tank tread. At it's cheapest it would be 7.00 a foot which would cheap enough for me. Mcmaster also is not know for being cheap.
Unread 31-12-2003, 11:09
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
We used attachment chain from Diamond Chain for our 2002 Robot. We riveted steel cleats to the chain, which were narrow enough to allow the drive to turn, but dug into the carpet to provide pushing force.
FIRST outlawed metal cleats in 2003, so I can see why you are thinking about putting rubber cleats on the attachment chain. We actually tried doing this in 2003, with urethane cleats. We aligned our wheels, kept the chain unbelievalby tight, and we STILL threw our chain off. The urethane does no allow for turning as well as metal cleats do, since they were wider and stuck to the carpet better than metal.
I am not saying that this rubber cleated chain drive system cannot be done, but I am saying that it will be risky and tough to make it work. Rubber likes to stick to carpet and chain likes to fall off of sprockets at the slightest side force, as it's moving... so be careful in how you design your tensioning system and wheel alignment system. Don't skimp on those two features. Ensure that your wheels get aligned and create a separate tensioning device to get maximum tension on the chain.
Good luck,
Andy B.
Unread 31-12-2003, 11:57
Ken Patton Ken Patton is offline
purple
FRC #0051 (Wings of Fire)
Ken Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond repute
Matt
I agree with Matt's recommendation to use #35. Some people think its overkill but I've seen the lighter chains break under impact often enough to not want to use them.
One additional (and I think very important) advantage to #35 chain is that it is less misalignment-sensitive than the smaller chains (1/4" pitch or 8mm pitch). This alone is a great reason (imo) to use #35.
Ken
Unread 31-12-2003, 13:30
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
Post Preseason Rant: Don't Go with #25 Chain in the last leg of your drive train!
And though this is sort of off topic, since the question has already been answered, I'd still just like to throw in my four cents about #25 chain ahead of time.
Originally Posted by Someone Will Say This
"#35 chain is so much heavier than #25, we've used #25 chain for the past 2,000 years and past 8,000 competitions and not once have we had a single strand of chain break EVER, and we've reused the same lengths of chain each year too. It is perfect in all FIRST applications."
Someone is going to say this. It'll be during week 2 of the build season, and a rookie team will ask for advice on chain in these forums. 40 people will reply, many of them like the above.
The truth is that there have been instances where #25 chain has broke on some teams' robots on the last leg of the drive train. Since the forces are relatively the same for about every team (and the only way to reduce this is by having poor traction or big sprockets) it's definitely in the best interest to not cut weight in something as critical as your drive train.
In addition, #25 chain will stretch significantly more over the course of the competition, and misalignment is not fun, as Ken has said. Let me be clear: chain stretching isn't a fun problem! Nobody gives high fives or a does a fancy FIRST dance because of chain stretching.
Originally Posted by Someone Will Say This Too
The Small Parts catalog says #25 chain has an average break load 925 lbs. Since A^2+B^2 = C^2 (or some other exciting formula) there's no way that you can ever break this chain. Look at the math, number cruncher Matt Adams, you're WRONG.
And numerically... I don't understand how or why it happens either, but it does. It's probably a dynamics forces thing. Every year there are teams that have #25 chain break on them. It's an extra couple pounds to ensure NO worries about this problem occur. It's well worth the weight to save on what could be competition altering failures.
So... there I go being blunt with a person that doesn't exist... If you disagree... I'm jealous of the 2 lbs you're saving this year.
My Advice:
#25 chain on the last leg of your drive train - Don't Go There.
My 4 cents,
Matt
Unread 01-01-2004, 13:10
Adam Y.'s Avatar
Adam Y.
no team (?????)
Would idler sprockets be ok in tensioning the drivetrain? Also would using a high durometer material lower the traction of the belting?
Unread 01-01-2004, 15:22
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
OK Matt, I'll bite! We have been using #25 chain for many years on our drive system. Ask anyone if we ever broke down because a chain broke. Last year we even used #25 chain for our wings and that never broke even though I thought I had designed it "on the edge."
Here is my real point: Noteworthy engineering is about making the proper trade offs in an intelligent way to maximize the efficiency of your design. To flat out say that one should never use #25 chain on your final drive is not appropriate. It is no different than saying that you should only use steel for your frame because aluminum bends too easily.
If you are careful to design your system such that it will not see significant dynamic loads, you can use #25 chain and not ever see a problem. Without getting into too many details, that loading depends on your gear ratio, coefficient of friction and a few other things.
Besides, in some cases, you prefer to have this "mechanical fuse" as your controled breakage point. As an example, depending on your design, you may prefer to fix a broken (or stretched) chain rather than a transtorque coupler or a keyway.
To answer Adam's original question about what happens if you run chain above it max working load but below it break load - it stretches gradually.
Raul
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 01-01-2004, 16:17
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
I am telling you now that #25 will and does break. Last year we continuously broke our chains. In one match we broke 3/4. I was told in 9 previous years we had never broken 1 chain. The difference is we went from 4 motor drive to 6 motor drive. The additional HP was too much for the chains. This year #35 will be our chain of choice.
25 or 35 chain? Alan Ing Technical Discussion 24 02-03-2003 13:56
Nylon Roller Chain Sprockets Jim Smith Technical Discussion 6 20-01-2003 20:01
1/4" chain and links from small parts archiver 2001 2 24-06-2002 00:18
Roller Chain Adrian Wong Inventor 3 23-02-2002 17:21
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
