Go to Post I think with so many facets of FIRST, success comes from learning the true meaning of teamwork through working towards a common goal. - Kristina [more]
Unread 02-01-2004, 22:17
Re: Drill Motor Adjustments -Rev vs Forward
The brush position has been beaten to death so far (all of it true)but there is something else that is a factor and that is the brush/commutator switching frequency vs. the speed controller switching frequency. This varies for motor types as the design of the commutator is optimized during the motor design phase. At some point the (high RPM) the two frequencies interfere with each other and the motor efficiency drops off. Also keep in mind that the difference in speed is greater at higher RPM. If you design the drive train and running speed to keep the motor away from running full RPM, you will minimize the effect. There is no substitute for practice, lot's of practice!
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
forward reverse on drill motor PDonovan Motors 2 03-02-2003 11:11
