Go to Post FIRST is the best thing that has ever happened to me...FIRST has taught me so much more than anything I learned in the classroom. The thing with my team, is we are so close, we are family, and I have figured out so much about who I am because of FIRST. - princessnatalie [more]
Unread 02-01-2004, 16:22
Robby's Avatar
Robby Robby is offline
AKA: Kevin Beranek
FRC #0269 (Cooney Robotics)
Robby has a spectacular aura aboutRobby has a spectacular aura about
Choosing a Linux distribution
I recently have decided to turn my computer into a dual boot system w/ Windows XP and Linux, but i'm not sure which distribution to install. I've had some experience with an older version of Redhat, but no longer have it installed. I was just wondering which distribution anybody would recommend.
Unread 02-01-2004, 17:28
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Re: Choosing a Linux distribution
Er... Redhat doesn't like Windows XP. I found out the hard way when my comp wouldn't boot either OS and I had to spend a few days extracting files at a friend's house and then reformatting. I found out later on the Redhat website that there was a warning for that. Oops. I think there's some fix to work that out if you really want XP/Redhat on one system, but I would suggest just finding an older computer (PII ~233mhz-400mhz) to run a dedicated linux box. Hope that helps you on the path of what not to do.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 02-01-2004, 19:13
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Be very careful, I've never gotten dual booting to work with Linux and XP.
That being said, there's a ton of "distros" out there, but each cater to a different taste.
I use Gentoo (http://www.gentoo.org), which is a source based "meta-distro." That means I can pick and choose whatever programs I want installed, compile them from scratch and hopefully optimize them for my computer, and then have an almost completely customized install. It's not really for beginners though, as there's no installer program, just a bunch of commands to type (although, they are very well documented). Another feature of Gentoo is the online community, which is the best Linux one I've seen yet (http://forums.gentoo.org).
Another good distro is Debian, which is similar to Gentoo but more stable and binary based. I believe their site is http://www.debian.org.
I think that it really depends on how much you want to learn. With Gentoo, I've taught myself much more about Linux than anything else, with other ones like Debian or Redhat, I had a working system, but no knowledge on how it works.
http://www.distrowatch.com
That website should be a good website to look at different distros, and figure out which is best for you. Narrow it down to a few, and then try them all out if you have the time. Nothing beats actually playing with a distro and learning how to use it.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 02-01-2004, 21:20
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
There are a few questions you need to ask yourself beforehand. What do you want to do with it? Desktop or server? Do you want ease-of-use or flexibility? Do you want it to auto-detect all your hardware on installation or do you not mind doing stuff like that by yourself? Do you like to dive right in? Do you want a simple way to install packages? Do you want something resume-worthy?
I mean, there are hundreds of distros for all different kinds of users. Most of my time spent on the internet is giving out free Linux tech-support via IRC. Doing that, I see all different kinds of users who just want Linux and didn't bother to even look into it. Probably the most popular distros I see are: Redhat, Mandrake, SuSE, Debian, Slackware, and Gentoo.
Now, those first three are some of the easiest distros to use, many think. They'll detect most of your hardware on install and set everything up all nice and pretty. That's fine. The downside is they're all RPM-based. Since you have used Redhat in the past, you probably know that RPM's are the packages for Redhat Package Manager. It's a decent package system, but I hardly recommend it. Just using rpm can send a person into RPM hell where there are packages that need to be installed but you think they're already installed and you have to fight the entire system. That's normally the biggest flaw of those RPM-based system. On the other hand, many companies have heard of Redhat and SuSE (many haven't heard of debian, slack, and gentoo). These distros will pretty much hold your hand through the installation and have GUI apps for about everything. You won't be forced to learn too much and it'll be about as easy to use as Windows.
On the other hand, Debian, Gentoo, and Slackware pretty much require you to get down and dirty. These distros won't auto-detect your hardware, they won't tell you exactly what to do during the install (but you can figure it out using the docs online), but they will usually leave less of a dent in your free space. These distros can be very customized. Gentoo has the trump on Debian and Slack; you can compile the entire thing from scratch to optimize it for your computer. These distros can pretty much run on any system where Redhat, Mandrake, and SuSE require pretty new systems just to install. These distros are great for running a server on a spare computer or really tinkering around. Also, Debian's apt and Gentoo's portage package systems are probably the best I've seen. They allow you to download and install the package along with all dependencies with one command.
In the end, any distro will work on just about any type of hardware.. Any Linux software will work on pretty much any distro. Anyways, the best way to find the distro that's best for you is to try a few. If you have broadband and a few blank CD's, you can install as many as you want.
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 03-01-2004, 09:18
Mandrake, SUSE, and Redhat all have tools that automatically resolve dependencies and keep you out of RPM hell. They are called urpmi, YAST, and up2date (or yum) respectively for the different distros. You only run into RPM hell when you install some random rpm you found on the web. However, you run into the same problem if you install a random .deb, ebuild, or .tgz.
You can do that in debian with apt-source. In that way Debian has the trump because you can install the binary when you are in a hurry, and compile from source when you aren't. The closest that Gentoo has (that I'm aware of) is a stage 3 install.[/quote]
Redhat and SUSE support the most hardware the easiest. Gentoo also supports a lot because you can patch your kernel as part of the install process. Generally, if your hardware is 6 months to a year old, it is very well supported. And once hardware is supported in linux, it is very rare for it to stop being supported, unlike windows.
You can also get CDs cheaply from cheapbytes.com. It sure beats trying to download on dialup (which I've done before) and borrowing CDs from friends (thanks Jim).
Unread 03-01-2004, 20:28
MichalSkiba MichalSkiba is offline
Low-Power BiCMOS Brain
#0854 (M.I.R.)
MichalSkiba will become famous soon enough
On a similar note, has anyone successfully installed Wine or something like it (ie. Bochs,...)? I'm running Slackware 9.1 and XP, but Slackware has been neglected since most of my software (MPLAB ) is XP/Windows based.
<<<theoldmanskiba>>>
2003 Canadian Regional Delphi Driving Tomorrow's Technology Award winners
Unread 03-01-2004, 22:20
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
I have installed Wine on Slackware 9.1 with good results. I was able to run Trillian, circutmaker, Microsoft Office, and others. I don't see why it wouldn't work with MPLAB (not sure about the loader program though).
Only one way to find out go download/install wine and see if you can run MPLAB (I would try and run a version installed by your XP installation.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 03-01-2004, 22:33
rwaliany's Avatar
rwaliany rwaliany is offline
R
None #0691 (HartBurn)
rwaliany will become famous soon enough
For those who couldnt get dual-booting with Linux and Windows working:
Sample Grub Config for my gentoo box
default 0
timeout 10
splashimage=(hd0,3)/boot/grub/splash.xpm.gz
title=Gentoo Linux
root (hd0,3)
kernel (hd0,3)/boot/bzImage2.6 root=/dev/hda4 video=mtrr,vesa:1280x1024 vga=0x31a splash=silent hdd=scsi theme=Gentoo
initrd= (hd0,3)/boot/initrd-1280x1024
title=Windows 2003 Server
rootnoverify (hd0,0)
makeactive
chainloader +1
If you need any help with anything, you can always message me. I've gotten just about anything working on Linux. I've used pretty much every distro there is as well.
R
Unread 03-01-2004, 23:02
Robby's Avatar
AKA: Kevin Beranek
Thanks alot everybody I really appreciate all of your replies. I think that I am going to go with Gentoo, I've already read through all the information and installation docs and it seems to be the right distribution for me.
Linux SteveC116 3D Animation and Competition 22 25-03-2004 15:07
Linux And Windows XP Raven_Writer Chit-Chat 4 06-08-2003 18:53
RoboEmu for Linux (PBASIC emulator) rbayer Programming 5 21-11-2002 21:08
Linux file extensions rbayer CD Forum Support 5 14-11-2002 23:04
MS Linux D.J. Fluck Chit-Chat 5 21-05-2002 17:47
