Go to Post You lame pig farmer! I'm not talking about a bunch of dudes sitting around eating their packed lunches that Mommy made. - Paul Copioli [more]
Unread 14-02-2002, 13:01
PyroPhin's Avatar
PyroPhin PyroPhin is offline
None #0263
PyroPhin is on a distinguished road
OI indicator questions
hello,i have a question concerning the lack of sufficent feedback LED's in the default code
our controller system has numerious LED indicators this year for the pneumatic system and various other things. i ran into a problem in that i ran outta LED varaibles. if someone knows how to connect more LED's to the OI or the varaible names for the last 2 indicator's on the OI (marked swich 1 and 2 if i remember correctly) it would be a great help.
Thanks alot!
-dan
Squee!
Team 263, Aftershock:
Alumni, guy who comes back and fixes Krass's mistakes
Unread 14-02-2002, 23:32
Page 21 of the System manual: LEDs labelled switch 1 thru 3 indicate the state of those switches on the RC, and are not available to the program.
Are you overlooking the possibility of using the dashboard port on the OI ? You can get a lot of feedback about the sensors on board, and a few of the variables sent from the OI to the RC (or all of them using the jumper on the OI).
Unread 15-02-2002, 04:56
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
You could always trigger the switch inputs yourself
Unread 15-02-2002, 08:53
Matt Reiland's Avatar
'The' drive behind the drive
We almost ran out of LED's on the board and considered using a switch with a bunch of contacts to select which 'set' of LED's to control. Therefore having 16 LED's on the board but only 8 active at a time and the switch both electrically connected the right ones and told the code to light up the right ones based on switch position
It seems like an option
Matt
