Go to Post When we stop asking ourselves the hard questions, whether as team leaders or in life, then we are failing. - Al Skierkiewicz [more]
Unread 03-01-2004, 19:20
Matt Fultz's Avatar
Matt Fultz Matt Fultz is offline
Matt Fultz has a spectacular aura aboutMatt Fultz has a spectacular aura about
Pneumatic Layout (Does it work?)
If anyone could figure out if this verbal model will work, that would be great. If it won't, please say why it wouldn't power the pneumatic cylinder, or say if anything should be added or changed. I could not make a picture of this, so I am just stating all connections.
Compressor to a brass T fitting. The "stem" (vertical) part of the T runs to a pressure gauge, the other end is run to the resevoir. The resevoir runs out to another brass T where the stem runs to a quick connect fitting to run tubing to a double solenoid and the other end of the T runs to a pressure switch to shut off compressor. The tubing runs to the double solenoid and out of the d.s. to the pneumatic cylinder.
If more detail or more parts are needed, please tell me.
Thanks!
Unread 03-01-2004, 19:28
SarahB's Avatar
SarahB SarahB is offline
SarahB has a spectacular aura aboutSarahB has a spectacular aura aboutSarahB has a spectacular aura about
Send a message via AIM to SarahB
Re: Pneumatic Layout (Does it work?)
Thanks!
That setup would work fine on its own, but would not be FIRST-legal. To make it legal according to the 2001-2003 rules you would have to go through the regulator after the storage tank before going to the double solenoid.
FRC:
Team 30 - FURY (Student, 2002-2004)
Team 229 - Division by Zero (Mentor, 2005-2007)
FLL:
Robo-Monkeys (Founder/Mentor, 2003-2006)
Currently working as a Radar Systems Engineer at Lockheed Martin in Liverpool, NY and pursuing my MSEE from Clarkson, while easing my way back into FIRST
Unread 03-01-2004, 19:35
you will want to put the release valve in there somewhere too, so you can depressurize the system after it has been used.
Unread 03-01-2004, 19:40
Matt Fultz's Avatar
Thanks for the replies.
If we put the release valve after the second brass T on another brass T with the stem having the release valve and the pressure switch on the other extension, would that work fine??
Thanks again!
Unread 03-01-2004, 19:43
I think you can put the release valve anywhere - usually its on the high pressure side, next to the first pressure gauge.
Unread 03-01-2004, 20:48
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
I don't believe the release valve was required by the rules (correct me if this is wrong). My team has left this valve off for weight concerns. I'm not suggesting you leave it off but it may not be necessary, depending on what you use pneumatics for.
Any other thoughts on this?
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 03-01-2004, 22:18
David Hoff's Avatar
David Hoff David Hoff is offline
FRC #4050 (Biohazard)
David Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to all
Matt and I are going to be using these pneumatics to make a design presentation that we will present to our team the week before kickoff.
Once again, thanks to everyone who's given us some feedback.
Cyber Blue Team 234: Indianapolis, IN 2002-2006
Purdue FIRST Programs: West Lafayette, IN 2006 - 2010
Cyber Titans Team 3793: Frederick, MD 2012
Biohazard Team 4050: Chambersburg, PA 2014
Unread 03-01-2004, 22:24
Umm Errr...
Hmm... Quick connect? Is that so you can pressureize the thing b4 matches w/ a beefier compressor? good idea.
1139 Alumni
Unread 03-01-2004, 22:44
dont use a beefy compressor
you might end up with Mad Bot Disease!
:c)
Unread 03-01-2004, 23:32
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
Thanks!
It would work outside of FIRST, but I dont think it's FIRST legal.
Heres how I would do it
Compressor to resevoir through the pressure switch (the pressure switch is on a "T" brass fitting) to gauge (also on a "T" fitting) to release/cutoff valve to solenoids.
Hope it helps
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 06-01-2004, 08:58
Matt Fultz's Avatar
We just need this to be a working model. I believe that our model is FIRST-legal, but if there is a specific as to why it is not, please let us know.
Thanks to everyong for their input!
Unread 06-01-2004, 10:44
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Refer to post #2,
That is what you would have to do to make the setup FIRST-legal. Adding in a release valve would also not hurt. Under the past few years rules, the compressor has to be the one in the kit, the max pressure going through the lines to the pistons is 60psi, and the max storage in the 2 given tanks is 120psi. The solenoids would also have to be the SMC models given or the bosch model. Previous years were very strict on what pneumatics you could use, but don't go buying anything till we see whats legal this year.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 13-01-2004, 12:54
Fred Hord Fred Hord is offline
Fred Hord is on a distinguished road
Thanks!
Looks like it will work. Look at the pneumatics manual and there is a photo of a typical layout.
Unread 13-01-2004, 13:19
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Using a "beefier" compressor would be illegal. Unless, of course, you put a steak on the FIRST compressor to increase it's beef level....
If you do not have the compressor on your robot (Pre-Pressurized for matches), you must use the compressor given by FIRST to pressurize your system. If need be, I'll find and cite the exact rule.
Unread 04-02-2004, 14:56
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
You definitely have to have the "primary regulator" after the storage tanks, to limit your "working pressure" to 60 PSIG.
Here's a little hint that we use to save compressor and battery wear and tear while testing:
Given a system similar to the diagram shown in the 2004 Pneumatics Manual where you have a "primary manifold" with the first gauge, sensor, purge valve, etc.:
1) To the FAR side of the purging valve, we've added a standard air hose male barb fitting.
2) We then dialed our shop air down to 120 PSIG.
3) We created a pneumatics "extension cord" with a male and female hose barb quick disconnect fitting attached to a 100' rubber air line hose.
4) Make a few spare "hose stub plugs" using a SMC pushon fitting, a dual female 1/8" NPT fitting, and a 1/8 NPT male plug (this can also be made using only kit parts with a spare 1/8" NPT "T" fitting and TWO plugs).
Now while testing, we simply jack our system into SHOP AIR, and open the purge valve. The hose allows us to be set up ANYWHERE in the shop. The system now fills in reverse via the purge valve. The robot sensor detects the 120 PSIG pressure, and keeps the robot's pump off. Since this is upstream of the primary regulator, NOTHING else changes. As long as your shop air exceeds the pressure switch's turn off value, you now have a full pressure, infinite air supply for testing purposes. This is quickly removed in one second by turning off the valve and popping off the quick connect, and the robot instantly falls back to "auto refill mode".
Given a small compressor and tank in your contest pit ALSO set up for 120 PSI max, this may also be used for a FAST air system "precharge" before your round without draining your robot battery nor requiring the umbilical and control board.
EDIT/
Ah yes, don't forget... To comply with safety rule 5.2.1 rule <R01>, on page 2 of the Robot.PDF, the external compressor in the pit ALSO has to be a FIRST kit style Thomas Industries compressor, ALSO set up to limit system pressures to 120 PSIG.
/EDIT
BTW, We also used this setup on the bench BEFORE the robot was assembled, to COMPLETELY test our pneumatic concepts WITHOUT requiring the RC, Spikes, or even the COMPRESSOR to be included. We simply used one of the above plugs to "stub off" where the compressor resides in the system, and ran the valves with momentary on switches (mounted in a Radio Shack plastic box) and a spare robot battery. This GREATLY speeded up our pneumatics system's development.
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Problems of the mind... effecting work Gadget470 Chit-Chat 20 18-11-2003 11:56
Edit doesn't work on original title posts??? Elgin Clock CD Forum Support 6 12-03-2003 17:30
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
Who knows how the motors [I]really[/I] work? Wetzel Chit-Chat 5 13-02-2002 21:50
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
