Go to Post looks like he was getting ready for a sprint! be careful chuck, its only like 2 feet from the line to the controls... - vivek16 [more]
Unread 06-01-2004, 00:49
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Re: Coefficient of Frictions
Here are the results of a test we did for RoboCup. This tested rubber on a felt carpet. It is similar to the FIRST carpet... This data is very good for comparison, but take the values themselves lightly, since the shape of the wheel and the carpet material will be different for FIRST use.
Buna-N: 1.29
Neoprene: 1.60
EPDM: 1.44
Viton: 1.11
Silicone: < 1.29 (not sure of exact value, but it is definately less)
- Patrick
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
Unread 06-01-2004, 15:55
mzitz2k's Avatar
mzitz2k mzitz2k is offline
Robotics Fiend
AKA: Matt Zitzmann
None #0302 (Mechanical Dragons)
Team Role: Student
mzitz2k will become famous soon enoughmzitz2k will become famous soon enough
Send a message via AIM to mzitz2k
Buna-N: 1.29
Neoprene: 1.60
EPDM: 1.44
Viton: 1.11
- Patrick
Interesting! What did the neoprene look like? There are so many different types... What was the hardness rating and did it have "teeth" or was it just a flat sheet of material??? If you have a picture of part number, even better!
Thanks again!
Matt
Team 302 - "The Mechanical Dragons"
Engineering Inspiration Award - Western Michigan Regional (2004)
Division Champions - Newton Division (2003)
Regional Champions - Great Lakes Regional (2003)
General Motors Industrial Design Award - Great Lakes Regional (2002)
Motorola Quality Award - Buckeye Regional (2002)
Regional Finalists - Buckeye Regional (2002)
Division Finalists - Newton Division (2001)
Regional Finalists - West Michigan Regional (2001)
Unread 06-01-2004, 20:16
patrickrd's Avatar
AKA: Patrick Dingle
The neoprene had Durometer = Shore A: 70. We used rubber o-rings as the test specimen, 1/2" outer diameter by 3/32" thickness (purchased from McMaster). This is a much smaller scale than used in FIRST. The o-rings were used for contact with the carpet on each roller of our omni-wheels.Testing each material was simply a matter of replacing the o-rings in the wheel. I've attached photos of the wheel and the test setup. In short, the weight of the setup provided a constant normal force, and a voltage was applied to the motor. The voltage was increased until the wheel slips. From this data it is easy to find out what the coefficient of friction is. The uncertainty is less than 5% for all the data.
- Patrick
ID:	1654  Click image for larger version
Tread or Wheels? Jordan A. Technical Discussion 28 10-01-2002 04:05
