Go to Post I know alot of the rookie teams were helped out alot this year. Do the same thing for the rookie Volunteers as well. - wilsonmw04 [more]
Unread 06-01-2004, 20:16
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Re: Coefficient of Frictions
Originally Posted by mzitz2k
Interesting! What did the neoprene look like? There are so many different types... What was the hardness rating and did it have "teeth" or was it just a flat sheet of material??? If you have a picture of part number, even better!
The neoprene had Durometer = Shore A: 70. We used rubber o-rings as the test specimen, 1/2" outer diameter by 3/32" thickness (purchased from McMaster). This is a much smaller scale than used in FIRST. The o-rings were used for contact with the carpet on each roller of our omni-wheels.Testing each material was simply a matter of replacing the o-rings in the wheel. I've attached photos of the wheel and the test setup. In short, the weight of the setup provided a constant normal force, and a voltage was applied to the motor. The voltage was increased until the wheel slips. From this data it is easy to find out what the coefficient of friction is. The uncertainty is less than 5% for all the data.
- Patrick
ID:	1654  Click image for larger version
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
Tread or Wheels? Jordan A. Technical Discussion 28 10-01-2002 04:05
