Go to Post changing some 0 to 1s was a lot lighter and cheaper than most of the clutches I found. - IKE [more]
Unread 07-01-2004, 07:24
rwaliany's Avatar
rwaliany rwaliany is offline
R
None #0691 (HartBurn)
rwaliany will become famous soon enough
IFI Loader for Linux
I've created something, it almost works, theres about 10 glitches on the writes and there is no verification yet, but it would be greatly appreciated if people could look over errors. It's roughly done, I'm just trying to get it to work currently.
debug-recv.txt - matches every sent line
debug-sent.txt - output on uploading EDU_default.hex
to run,
mkdir test
cd test
tar -xzvf /path/to/ifi-linux.tar.gz
make
./picloader EDU_default.hex /dev/SERIALPORT
http://ryan.scv.net/x2545/ifi-linux.tar.gz
http://67.115.226.221/x2545/ifi-linux.tar.gz if the above link doesn't work due to my name server being down.
I'll work on it some more tomorrow, or thursday.
R
Unread 07-01-2004, 13:45
Skabana159's Avatar
Skabana159 Skabana159 is offline
Robotics and Field Hockey
AKA: Jesse C. Owens
#0159 (Alpine Robotics)
Skabana159 is on a distinguished road
Send a message via AIM to Skabana159
Re: IFI Loader for Linux
Originally Posted by rwaliany
I've created something, it almost works.
Ryan, I could just about kiss you. I will try to test this, but it may be hard to get the EDU RC until we actually have the RC on saturday...
"What most people do not understand is that the Buddha, the Godhead, resides just as comfortably in gears and circuits as in hills and trees. To believe otherwise is to dilute the Godhead."
-Robert Pirsig, Zen and the Art of Motorcycle Maintenance
Unread 07-01-2004, 13:59
rwaliany's Avatar
R
Note: If you look at the debug-sent.log it appears, if you send a write with an invalid checksum you will receive
00 0F 02 FE 04
instead of
0F 0F 02 FE 04
or any wriet with an invalid command
00 + Last command
I'll work on those today, got done at like 5am last night. I'm hoping to have it completely before Saturday.
Thanks,
Ryan Waliany
R
Unread 07-01-2004, 14:50
A couple of suggestions (I can't actually do anything usefull with the program since I don't have a controller)
When you tar up the stuff, do it from the previous directory, so that you don't have to copy the tar file to a new directory. Also, use some type of version number or date in both the tar file and the directory for your sake, and everyone else's. You can use a command like this for the tarring: tar -cvzf ifi_loader-0.01.tar.gz ifi_loader-0.01/
Right now, you program is copyrighted and you have all the rights and protections that provides, which means we can't modify it. I assume, since you are releasing it to us, that isn't what you intended. Thus, you need to license the code to give up some of your copyright rights. There are virtually unlimited open source licenses, some of which are listed at http://www.opensource.org/licenses/ You should choose one of those (I prefer the BSD license) and license your software with it.
Can you include a short readme that tells, at a minimum, where to get the information that you used to write this loader?
Thanks for the time that you've spent on this.
Unread 07-01-2004, 16:48
mikew mikew is offline
crazy coder
#0613 (Franklin RoboWarriors)
mikew is an unknown quantity at this point
Send a message via AIM to mikew
Looks like someone had more time than me. Cool.
GPL!
Unread 07-01-2004, 17:49
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Joe,
The info can be found here: http://www.microchip.com/download/ap...c16/00851b.pdf (Well, Ryan may have other sources, but that should provide most of what you need)
Also check out my (basic) notes here: http://www.chiefdelphi.com/forums/sh...395#post196395
Unread 07-01-2004, 21:15
rwaliany's Avatar
R
Thanks, I know. I haven't had time, I finished it and decided to upload to people to look at at like 5-6am in the morning. I've only spent two days actually working on it trying to parse the data and write it and a couple days just looking over the packet communications. I'll try to finish it sometime tonight, I've been working on our blimp project and haven't had time today. By Monday, I'll have GPL, etc...with versions. Anyways I'm going to work on it around 11PM Pacific Time, if anyone wants to help on AOL instant messenger, screenname "Ryan Waliany" Today the other control members burnt out the EduRobot by hooking it up to a power supply, but I've managed to use a backdoor to turn it on by skipping the on switch. So I might be able to finish it using the EduRobot still. If not, It might have to wait till next monday.
Thanks,
Ryan Waliany
R
Unread 08-01-2004, 01:48
rwaliany's Avatar
R
IT WORKS IT WORKS IT WORKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
I'll put up a source forge page soon and add a graphical interface!!!!!!!!!!!!
LINUX HERE I COME!
Get releases here...
http://ryan.scv.net/x2545/picloader/
tar -xzvf ifi-picloader.0.1.tar.gz
cd ifi-picloader
make
./picloader (HEX) (SERIAL)
ex:
./picloader EDU-default.hex /dev/usb/tts/0
Talk to me if you want to help with GUI, would you people prefer GTK QT, or?
Also, new website for it, http://ryan.scv.net/x2545/pic/ soon to be at sourceforge.net.
Thanks,
Ryan Waliany
R
Bug in IFI Loader rwaliany Programming 2 06-01-2004 21:26
IFI Loader on ME LBK Rules Programming 1 18-12-2003 17:49
IFI Controllers For 2004 Ian W. Rumor Mill 22 01-10-2003 16:09
Extra 2002 IFI controllers Ryan Foley Electrical 0 03-09-2003 22:53
How much code can an IFI controller handle? Larry Barello Programming 7 10-02-2002 19:06
