Go to Post The teams that know how to build good robots are the same teams that know how to build good teams, and they engage the students every step of the way. - Chris is me [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 07-01-2004, 12:54
Pin Man Pin Man is offline
How you doin'?!
AKA: Dave Kingsley
FRC #0088 (TJē)
Pin Man has a spectacular aura aboutPin Man has a spectacular aura aboutPin Man has a spectacular aura about
Send a message via AIM to Pin Man
Interested.... HTML
I was interested in programming a forum just like chiefdelphi but just for my team to view... Is this possible to do with HTML because I know a good amount of HTML to get started but if I had to I would learn PHP...
AIM SN: ThursdayCambria
Attending Bridgewater State College
Shirt collection- 25, 47, 69, 140, 173, 191, 213, 303, 365, 461, 836, (2)862, 885, 888, 1027, (2)1073, 1156.
Shirts in the works-
Shirt Wish List- 45, 48, 61, 67, 84, 86, 95, 103, 111, 126, 175, 190, 233, 236, 716, 870, 871, 1114, and any other team basically
Unread 07-01-2004, 12:59
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Re: Interested.... HTML
You can't do any kind of dynamic website (forums, etc) with just HTML. You will need some sort of scripting language (php, perl, cgi, asp, etc) that can either connect to a database or some kind of data storage.
Brandon Martus
e-mail
Unread 07-01-2004, 13:04
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
I use phpBB for the Cyber Blue 234 forums. It's fairly easy to install, but your webhost must support php and mysql databases. Quite a few teams have used this typed of forums and there is a large support group that could help you if you need it.
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 07-01-2004, 15:12
iamnafets iamnafets is offline
Meh?
AKA: Stefan Mai
None #0624 (CRyptonite Robotics)
iamnafets is on a distinguished road
If you are interested, I suggest you learn one of the major server side languages or at least a client side one that can connect to a DB. I HIGHLY recommend PHP because it has a lot of flexibility: no delarations, strings are native, hundreds of string functions already built in, FREE, etc. The best way in my opinion is to buy a book and have at it. But if you already know how to program, you can probably find a guide on the internet. It's pretty similar to the normal C and others with the syntax. Like if(){ }else{ }. The variables don't need to be declared but it doesn't mean you can't cast them. Each variable also needs a $ in front of it. And that's about it. Look at some of the code that is readily available as most all of the scripts out there are free and ALL are "open" source. Have fun!
Cryptonite Robotics Team 624
http://www.cryptoniterobotics.com
If it's down, someone needs to buy me a UPS and tell the thunderstorms to stop crashing my server.
Unread 07-01-2004, 17:30
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Hello,
How large do you think your forums will be? I created my first set of web based forums using just batch files and a large text file (in a ramdisk) was the database.
If you want to create a simple, one-time set web application, batch files/shell scripts will suffice. Once you start working with text processing, I recommend you move on to Perl. Perl may be strange in syntax, especially regular expressions, but they are incredibly handy.
If you start to need functionality that Perl cannot easily provide, like interfacing with SQL, networking, etc., then you move on to PHP. I believe that Perl is easier to learn than PHP, but not too many people agree with me here.
One advantage of learning PHP is the ease at which you can connect to an SQL database. Those databases can hold tremendous quantities of data and process it efficently.
Good luck!
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 07-01-2004, 17:46
How you doin'?!
AKA: Dave Kingsley
FRC #0088 (TJē)
Yeah, it doesn't matter if its like the chief... I mean that would take forever... I just want something very small to boost the communication within the team...
Unread 07-01-2004, 18:06
FRC #0030
Smile Re: Interested.... HTML
Ok,
Tell me more about what exactly you want to make and what equiptment you have available. For example, if you want to run a team communications system on a web server, you would need the capability to run scripts on that computer. If you are self-hosting, this is not a problem. Otherwise, talk to your web hosting people.
If your team is not too big and does not require a professional solution, I could help you. Otherwise, you could use phpBB or the like to create forums, and allow only your team to access.
I would recommend either phpBB or Coranto for internal team use, as they are both easy to use. Of the two, I lean towards phpBB.
Good luck. again.
Team 30, 2002-2005
Unread 07-01-2004, 20:14
How you doin'?!
AKA: Dave Kingsley
FRC #0088 (TJē)
I just want something that only my team can go into and say something like an announcement or something... We have a team email system but sometimes things happen so fast that the email doesn't get out and its too late... On average we have about 75 students in the beginging and in the end we usually end up with 40-50... I don't expect this to be anything elaborate like this but something small and easy to use so not just one person can run it... I don't like it when just one person is in control... But yeah just basically for communication...
Unread 07-01-2004, 20:55
busy.
AKA: B. Slash Kamen
phpBB2 is probably your best bet, then, assuming you have the right setup.
Brandon Martus
e-mail
Unread 07-01-2004, 21:22
How you doin'?!
AKA: Dave Kingsley
FRC #0088 (TJē)
thanks, I'll take a look at it... Any other comments or anything on how I could do this please... I need any help that I can get...
Unread 07-01-2004, 22:34
Meh?
AKA: Stefan Mai
I made a PHP email system for our team. More like an intranet with groups and other things. Dunno, I think it would be hard to port and I don't have much time to do it now that kickoff is close .
Unread 08-01-2004, 18:00
Scott Shaw 237's Avatar
Scott Shaw 237 Scott Shaw 237 is offline
Hey! Must be da money!
AKA: Shaw 2
FRC #0237 (Sie-H20-Bots (T.R.I.B.E))
Scott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond repute
Send a message via AIM to Scott Shaw 237
Team237.com.forum uses the phpBB2 forums. They work really nice for team communication. The only problem is that your server needs to be able to host .php and has a mysql database. If you cant find one, I know that tripod has a blog that is somewhat like a forum, but more of an important messages thing that can be responded to.
2000 UTC Regional Winners Thanks 131 and 209!
2000 J&J Sportmanship Award
2002 NYC Regional Winners Thanks 549 and 358!
2002 Leadership in Controls Award
2003 Delphi Driving Tomorrow's Technology Award
2004 J&J Regional Winners Thanks 56 and 303!
2004 GM Industrial Design Award
2004 Motorola Quality Award
2005 New Jersey Regional Finalists Thanks 56 and 303!
2005 Radioshack Innovation in Control Award- FLR
2005 Radioshack Innovation in Control Award- NJ
2006 GM Industrial Design Award
2006 Delphi's Driving Tomorrows Technology Award
Unread 09-01-2004, 08:53
Robert Hafner's Avatar
Robert Hafner Robert Hafner is offline
FIRST Alumni
Robert Hafner is on a distinguished road
Send a message via AIM to Robert Hafner Send a message via MSN to Robert Hafner Send a message via Yahoo to Robert Hafner
My team uses YaBB Forum.
You can look at our forum at www.team96.org
If you need help programming in PHP, I'll help. OUr website (built by me) is in PHP.
Anyone interested in attending an Invitational in Keene NH? DirtyBird213 Off-Season Events 13 23-07-2003 09:03
Any good HTML editors available? PMGRACER Website Design/Showcase 23 07-06-2003 21:02
Would any SoCal Teams be interested in an exhibition game? ahecht Off-Season Events 1 14-04-2002 23:21
Anyone interested in a Mascot competition? DUCKIE Chit-Chat 6 05-04-2002 21:31
Request for HTML to be allowed. EddieMcD CD Forum Support 16 13-02-2002 18:55
