Go to Post ...several people have told my that my brain has been oxygen-starved since at least 1975. - dlavery [more]
Unread 08-01-2004, 14:55
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Removing encryption from the pdf's
Before you all go crazy about me wanting to break the encryption on the rules before Saturday, that is not the point of my post. I merely want to know how to remove the encryption once FIRST gives us the password and I can open the files. I don't want to have to type the password every time I open the file. I know one solution is to re-download the files Saturday afternoon, but is there another way?
Unread 08-01-2004, 15:32
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
Re: Removing encryption from the pdf's
I'm pretty sure there is not another way.... like you said, FIRST will be posting non-encrypted versions on their website... as of noon (i think) on saturday.....
so just re-download and you'll be all set...
I assume the reason they did the encryption was so the representatives at kickoff could already have the files on their laptops or PDA's to view the rules at kickoff.. It also helps reduce the server load on saturday so there is not 20,000 people downloading the same file all at once.... although thats probably going to happen tonight
Tom
Unread 08-01-2004, 16:29
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Yes ... it is very easy. Once you have the file open you go into the file menu under Document Security. Click on "Change Settings" and uncheck the box for "Password Required to Open Document". Then when you save it the password will no longer be required.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 08-01-2004, 16:46
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
This would only work for Adobe Acrobat, not just the reader, right?
Unread 08-01-2004, 16:47
Stu Bloom's Avatar
OOPS ... I didn't think of that since we have the full blown Adobe here at work ...
You may be right! OUCH!!
Stuart Bloom
Mechanical Engineer
Unread 08-01-2004, 16:50
FRC #0078
... just upgraded my acrobat reader, so i assume you need the full version of Acrobat since i can't find what Stu was talking about...
Unread 08-01-2004, 17:43
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
Yep ... you need the full version of Acrobat to perform any save function at all.
I ran into this problem when trying to fillout college application PDF's!
